Old 05-23-2015, 10:03 AM   #1
LBJ
LBJ's Avatar
Drives: 2012 camaro 1LS. M6
low miles deferential
What is considered low miles on deferential I have a v6 differential with 35k and I going to put 391gars in should I replaced all the bearing. .? or only gears. .? need advice
Mods..mrt v2. Cai intake v max throttle body. 20% windo tint & RX catch can Gianna 20in rims nitto 555 & afterburner tail lights RS halo head lights & gm heat extractor 4 pack gauges & panted heritage Grille & zl1rear sproler t5 splitter custom head rest
LBJ is offline   Reply With Quote
Old 05-25-2015, 12:15 PM   #2
762ch
Drives: 2011 2SS
Those are a lot of gars! 35k is pretty minimal, as long as it doesn't look beat to heck its probably fine. Check all the seals and make sure nothing is stripped or broken before you take out the old one.
762ch is offline   Reply With Quote
Old 05-25-2015, 04:43 PM   #3
LBJ
LBJ's Avatar
Thanks I will check it out
Old 05-26-2015, 12:24 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Don't think V8 gears will fit a V6 housing not 100% sure but pretty sure...
Old 05-26-2015, 12:55 AM   #5
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
If it's a manual you can use em if it's a auto. No go it's a smaller irs
https://www.youtube.com/@FredJrsGarage
‘19 Silverado 3500 dmax
‘77 trans am
‘63 c2
Shopping for more Camaros
Vroom_vroom is offline   Reply With Quote
Old 05-26-2015, 07:04 AM   #6
LBJ
LBJ's Avatar
It a manual & I have the manual .I just wanted to make sure win I do the switch that I get everything I need
Old 05-27-2015, 08:52 AM   #7
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
minor suggestion:
the cost for bearings and seals are quite low compared to the cost of the install. best to go with all new while you have it apart.
also open the diff carrier and look at the clutches.
then you will have a new diff and not have to worry
just my 2cents
h018871 is offline   Reply With Quote
Old 05-27-2015, 09:47 AM   #8
LBJ
LBJ's Avatar
I think h018871 is right better safe than sorry
Old 05-27-2015, 01:21 PM   #9
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You sure you want 3.91 gears? I thought the M6 for the V6 was already geared very low.
Old 05-27-2015, 03:30 PM   #10
LBJ
LBJ's Avatar
No I have 327 gears
Old 05-28-2015, 08:53 AM   #11
CamaroCracka
No, I mean first gear in the trans. It's like 4.something. Much lower than the TR6060 first gear. I thought I read that somewhere but I could be mistaken.
If I am correct, it could render first nearly useless for you.
Old 05-28-2015, 02:47 PM   #12
LBJ
LBJ's Avatar
My bad...iam not sure what 1st gear is but I put taller tires on & talking to people that has them I think I will be ok
