![]() ![]() Drives: SIM 2010 2SS/RS LS3 LPE750 Join Date: Feb 2012
Super Chiller
Haven't seen anything in a while on the Super Chiller, anyone use them still? If so any long term problems?
![]() ![]() Drives: 2010 2SS Join Date: Sep 2012
everybody wants one. somebody should start making them.
as a sidenote, RX products arent the greatest.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
![]() ![]() ![]() ![]() Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
I'm sure someone will fill the void with a good product.
I've had my chiller, built by Dave, for 3 years. Still works fantastic. Zero complaints.
750HP of Twisted Reaper!
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes Join Date: Oct 2010
......so what was the problem with the Super Chiller?! Guess i dodged the Bullet on that one cause i almost pulled the trigger on one a while back!
Fear the LMR Twisted Reaper Brotherhood!
#6 | |
#7 |
![]() ![]() ![]() Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
Go meth injection.
#8 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
#9 |
I have one of Dave's kits. Been performing flawlessly for the past 2 years with ZERO issues.
#10 |
![]() Drives: 2011 l99 Join Date: Aug 2012
superchiller
I have one from Dave too. It's ben on my car for 2 1/2 years. I've had o problems, no freon leaks, no anything. On a 95 degree day, you can dip your finger in the holding tank and the coolant is very cold! Hard to get but worth the wait.
#11 |
What is their cost?
#12 |
Drives: none Join Date: Oct 2012
You can't get them really
#13 |
When I purchased mine, there were two options: 1) Street, and 2) Competition. I think the street version was about $800, and the competition was $950-1000.
#14 |
![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 Join Date: Aug 2009
I had Dave's SuperChiller on my 2010 SS & it is running great with no issue's , then i got RX SuperChiller for my 12 ZL1 it was running good first then started leaking & killing my AC Compressur .
I hope he gets back on track & get my SuperChiller from him. Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
