Old 05-24-2015, 06:57 PM   #1
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
which hawk pads to get fo wheel conversion
moving to 17 and 18 inch wheel setup, and need to change out the front brake pads, for the star industries front wheels to fit, which will remove my front roller skates off the stock pads. What does everyone recommend for a main street car, 730 rwhp, with going to track few times a month, and I do more burnouts, with line lock more now too.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 05-26-2015, 01:36 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
I'd suggest the Hawk HPS 5.0 pads.
Feel free to call, PM or email me anytime with questions and I'll be happy to help get you set up.
Best regards,
Tyler
888-308-6007
