05-25-2015, 10:11 AM | #1 |
Really, Really Fast
Drives: 2010 Camaro SS Join Date: Feb 2013
Went 9s on the first shakedown pass!
Went to the track Saturday. Was racing in the streetcar class in SCT. Drove it over an hour to the track. Then went on a 20 mile cruise. Very first shakedown pass on the new setup, the car went 9.8@141mph.
Next pass up, I launched it at 2500rpm and snapped the stock axel. (Time for upgrade lol) Now to let it eat and launch it properly. Hoping to hit some really low 9s next time at the track. Video of run, that's a 1200whp gtr I'm racing https://youtu.be/dcvFyQtbVbg
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
05-25-2015, 10:15 AM | #2 |
Treasure Coast Camaro 5
Looking GOOD!!!!!!!!!!!!!!!!!!
05-25-2015, 01:00 PM | #3 |
Congrats on a nice first pass. Care to post the slip? And I'm sure I've asked you this before but what gear you running? Hoping to get my new motor and F1A tuned soon and hit the track.
You still on a Maf tune? |
05-25-2015, 01:54 PM | #4 |
Sounds like you need to see if someone will sponsor a rear setup.....
05-25-2015, 03:12 PM | #5 |
Really, Really Fast
Running 327 gear in the rear
05-25-2015, 03:15 PM | #6 |
Really, Really Fast
Wish I had a sponsor.
05-25-2015, 03:34 PM | #7 |
3.27 rear huh?!....
You dont even need that OD then.
05-25-2015, 04:59 PM | #8 |
Really, Really Fast
Its still rocking the factory rear and axels. So still had 3.27s. Gear fits the setup pretty well. So I won't be changing them. Just need to order some 1400hp axels.
05-25-2015, 05:38 PM | #9 |
Too much is never enough!
Ive got some DSS 1400 hp axles that will be available soon, H-E tied me up and forced me to buy a rear end setup from him!
Great pass man!
05-25-2015, 09:49 PM | #10 |
Drives: ZL1 Camaro Join Date: Feb 2009
Great pass....I respect the fact that the car is driven to and from the track....very cool, GL with getting into the 8's!!
05-26-2015, 12:44 AM | #11 |
Drives: 2013 SS Join Date: May 2013
That's sick your the 5th 5th gen I've seen and heard that's still on the stock rearend without any issues at that power level!!!
05-26-2015, 09:23 AM | #12 |
Drives: 2010 2SS Join Date: Nov 2013
H-E is a great guy to deal with. Found a disconitued part for me and made it all happen on a tight deadline. Wouldnt hesitate to call him when I need more parts for the car.
05-26-2015, 10:02 AM | #13 | |
Really, Really Fast
It will Def be getting a zl1 center and new axels I'll be giving H-E a call this week
05-26-2015, 10:30 AM | #14 |
Drives: 2014 Saleen 620 White Label #14-011 Join Date: Dec 2014
Incredible stuff!
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors, ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs, BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned! 573WHP/557WTQ @ 10psi. Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708 |
