Old 05-26-2015, 10:19 PM   #1
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Strut Tower Brace
Is there anyone out there with OEM Strut Tower Brace to 2010 car adapters???
Haven't seen anything on these for sometime now
Old 05-26-2015, 10:30 PM   #2
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Yep, right here
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 05-26-2015, 10:56 PM   #3
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Originally Posted by krisprz2010camaross View Post
Yep, right here
Right where?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 05-26-2015, 11:03 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Kinda looking for a set
Old 05-26-2015, 11:12 PM   #5
JusticePete
Drives: Camaro Justice
You don't need a strut tower brace. Do you appreciate how much money I am saving you?
Old 05-26-2015, 11:35 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The strut tower brace is a waste of money?? An YEAH!!!!
Old 05-26-2015, 11:41 PM   #7
JusticePete
It was installed for the tuning of the MRC in the ZL1 to take out a resonance that was inferring with the data logging. In cars that are tracked they find the turn in is slower with the STB. Aside from an all out race car, there is no tangible benefit that has been documented by anyone.
Old 05-27-2015, 01:02 AM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Well they have a "looks cool" factor....that has to count for something. lol
Mods:
Old 05-27-2015, 02:42 AM   #9
krisprz2010camaross
Originally Posted by Dizzy82 View Post
Right where?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 05-27-2015, 08:44 AM   #10
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
dont need brace
How about on the convertible?
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 05-27-2015, 08:54 AM   #11
JusticePete
Does the 5th Gen Camaro Benefit from a Strut Tower Bar?
The brace was and is necessary when the roof is cut off. That is why TEAM Camaro designed and install the brace installing the Vert. The brace is installed on the ZL1 indirectly for NVH. The STB cleaned up some 'noise' on the sensors used to fine tune the MRC. The STB looks cool so it is part of the 1LE package.
It would deny the obvious to say the OE STB does nothing. It does add structure to an already robust monocoque. There is zero data available that documents any gain in handling or lap times. None.
Car and Driver Stress Test
Simons has discovered slipping suspension-member attachments and steering linkages sending false signals to the driver. Once, a race car’s control arm collapsed when subjected to normal cornering loads. His K&C machine has helped teams determine why one race car responds quickly to setup adjustments even as its identically constructed stablemate is a cranky handful. Simons adds that he’s never seen an aftermarket strut-tower brace provide a measurable handling benefit.
When you are considering the modifications you choose to make to your Camaro, we strongly suggest you take a holistic approach and discuss the entire range of modifications with your JPSS Suspension Specialist. They can guide you through the selection process to make certain that each modification compliments all the others to create the best possible custom Camaro for your personal use at the most reasonable cost. Do it right. Do it once.
Read more about the 5th Gen Camaro
Old 05-29-2015, 04:59 PM   #12
Soloshawn
Drives: 2011 Camaro 2SS/RS
Here is the answer you were asking for. I have a 2011 2SS/RS that was built in 7/10 and did not have the 2011 adjustments to the towers. I bought the Convertible tower strut for stiffening and used the TPIS 952-448-6021 from Chaska, MN and the car handles flat through corners with the addition of PFADT sway bars. Plus it looks cool if people look under the engine.
Soloshawn is offline   Reply With Quote
Old 05-29-2015, 05:09 PM   #13
Soloshawn
I would add that having been a racer since 15 years old that most people on suspension are selling snake oil. You don't improve on your vehicle until you are driving it at at least 110%. Then you can decide where to put your money. Improve your skills before dumping money into dreams. if you are not on a race track or doing track days all this is a moot point. The car is better than you in normal driving conditions. My car understeers terribly like most Camaro's do at the track. I have driven around the point and improved my driving. Now it is time for me to get a camber and castor adjustment for the track. I ordered one from Moreno. After that maybe tires and wheels. But that is going to save me what 2 seconds on the track? Drive as hard as you can with what you have.
Old 05-29-2015, 05:30 PM   #14
krisprz2010camaross
I definitely felt the difference in the corners when this was the only handling upgrade I did.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
