Old 05-28-2015, 10:24 AM   #1
jesse454545
Drives: 2011 CAMARO 2SS/RS
Lowering Spring Guidance.
I have a 2011 camaro SS and would like to get it lowered. I have 22 inch rims on it with low profile tires I also have long tube headers where the off road pipes sits about 1/2 lower than the car. I would like to lower my car more than 1" so about a 1.4" is what im looking for but don't know if it would be okay becouse of the rims and long tube headers. Has anyone with LT Headers or 22" Rims gone lower than a 1" drop on camaro if so can you post pictures. Thanks for the help.
jesse454545 is offline   Reply With Quote
Old 05-28-2015, 11:38 AM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
The lower you go, the more you'll have to watch out for inclines and speed bumps. I recommend sticking with 1" to 1.25". With your setup, I'd probably go 1.25"
Best regards,
Tyler
888-308-6007
Old 05-28-2015, 12:28 PM   #3
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
The 22"s will help keep the car higher off the ground while filling in the wheel well. If you ever go to 20"s, depending on tire sizes, then you may have a harder time in certain driveway ramps and speed bumps. Just something to keep in mind
Jenner is offline   Reply With Quote
Old 05-28-2015, 04:14 PM   #4
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
If you decide to go with 1" I may have the fronts available this weekend. I'll let them go for $75
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
headers, lowering kit, springs
