Old 06-01-2015, 02:05 PM   #1
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
Offset suggestions - and tire size suggestions
okay guys what is the best tire to run for my wheels.
they are boze wheels 20x9 +32 and 20x10.5 +38
I edited this post as too avoid opening another....
revived is offline   Reply With Quote
Old 06-05-2015, 07:31 AM   #2
alday72
Drives: 2011 camaro ss
I just recently purchased forgestar f14 9.5x20 11x20 im thinking about running a 245/45/20 in front and a 305/3520 in the back i was told that. I would have any problems but i dont know if thats going to look right ,has anyone on here ever done this setup?
alday72 is offline   Reply With Quote
Old 06-05-2015, 08:04 PM   #3
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Originally Posted by revived View Post
Can I run 255/35/20(9") & 295/35/20 (10.5") without setting off the monitors and will this throw off the speedo?
255-35-20 is 27" tall
295-35-20 is 28.1" tall
yeah that will give stabilitrac issues.
check here http://www.camaro5.com/forums/showthread.php?t=62838
Your good for stabilitrac they are off by a little more than a 1/4 inch. which is ok.
I'm not sure on how its gonna look though.
Its easy to figure out sizes that are not listed use the formulas below.
width x aspect % = sidewall height
multiply this times 2 then divide by 25.4 this will give you the total sidewall height in inches.
now add your wheel size to get the toatal height.
A 255/35 R20 tire would be
255 x 35% = 89.25mm (or 255 x 0.35)
89.25mm x 2 =178.5mm now divided by 25.4 is 7.03 inches.
7.03" + 20" wheel is 27.03" total height.
GVA 45TH 2SS is offline   Reply With Quote
Old 06-07-2015, 03:46 PM   #4
revived
Vrrrm.
revived's Avatar
bump got the exact Offsets, and now I need to find the right tires.
Old 06-08-2015, 08:37 AM   #5
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
245/45 really isn't quite enough tire for 9.5" wide rims - I think something more like 265/40 might be a better overall match for the 9.5" wheel width and your 305/35 rear tire size.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 11-15-2017, 04:56 PM   #6
datagram940
Drives: Camaro 2SS RS
Arrow
Hi guys!!!!!
Can I put on the rear 20x11 ET37 with 315/35 20 tires?
ET37 is a problem?
Thanks.
datagram940 is offline   Reply With Quote
