![]() Drives: 11 2SS/RS M6 vert Join Date: Dec 2010
Question on alignment and tire wear
I have mostly BMR bushings, toe rods, and trailing arms on my SS. After I changed to these I went with the Pedders street performance alignment. The rear alignment specs are not that much different from the OEM, rear camber went from -0.4 to -0.5, but I went through a set of rear P Zeros in 3300 miles. I do not drive the car too aggressive (I don't think I do). They look like the wear is somewhat even. The outer edge is a little lower than the rest, but not by much.
Do I have some other problem or are the tires just that soft? I see others getting 15k or more.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
I sent this in a PM to justice Pete a few weeks ago and never got a response. Any one?
Flying da helicopter
3300 miles on Pzeros is a little low. They should be able to get at least 15-20k miles before being replaced. Is is both front and rear wearing so fast?
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Most likely a toe issue, toe is what will kill tires, not so much camber. I run -2.1 camber in front of my car and haven't noticed any major wear on the front. If you have a lot of toe though it will eat tires very quickly.
I've put well over 1k miles, had almost 4 hours at VIR and 2 autocrosses on a new set of M/T Street comps and they're looking just fine even with the -2.1 camber up front, and I have close to -1 in the back, but very little toe.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
#5 | |
Drives: 1969 SS/RS Camaro Join Date: Nov 2013
Once upon a time, my LCA bushing in the front of my car went out and affected my toe settings. It ate through my tires in no time. |
#6 |
The fronts are fine it's the backs I have trouble with. I had it aligned to the pedders spec's 2 years ago. I watched the guy do it and he got it right in. The spec's call for 0.10 total rear toe. That does not sound like a lot.
#7 | |||
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
Kind regards, Jordan Priestley 888.308.6007 |
#8 |
Yeah, 2 years is a long time to go without an alignment, it's most likely out of spec now. I think it's typically recommended to get it re-aligned about every 6 months. Honestly I go about a year though without any issues normally.
Pot holes and rough roads will eventually just knock it out of spec.
2010 2SS
#9 |
I'll get it aligned again and see if it was off.
#10 |
It was the rear toe that was out.
