Too much is never enough!
MSD BAP Max Voltage??
For those of you running an MSD 2351 BAP, What voltage are you running? I have heard that there is a max voltage and not to go past that. Wondering what that is. I am running Livernois dual pumps. So far my highest voltage is 17.
Also is it necessary to ramp in the voltage or can I just kick it in where I want it?
![]() ![]() ![]() Drives: All things Turbocharged Join Date: Dec 2010
19v
been working fine, long termBeen running 21v in a test car just to see if it will actually burn out the pump. |
#3 | |
Orange wire to fuse block, red wire to FPCM.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Ramp it so there is no shock to the pump. 17v is the "safe" amount. Some go 19v like was said.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
This is at 19 volts, should have FP like this?
This was the best of three runs before the laptop battery died, but its actually as low as 47.
Build thread http://www.camaro5.com/forums/showth...55#post8107855 Last edited by 1KillerSS; 06-03-2015 at 03:49 PM. |
#6 |
You're using up all the fuel in that darn engine!!! If FP goes any lower you're going to need more pump. The dual CTSv pumps are two small pumps, only worth a little more power than a ZL1.
#7 | |
That's pretty much saying the same thing as if I go any higher on the boost, I'll need more pump. Thats a bummer Was really hoping to get better than 800 out of my dual pump setup. Thanks for all the help, as usual, you guys take good care of me.
#8 |
I thought that pump with a booster was supposed to be good for 850whp.
Maybe it's the trims inside the FPCM latency ramping up to full duty. Maybe try wiring the MSD with constant power to the orange wire. That way the FPCM won't forget to go strait to 100%. |
#9 |
I thought the same, but I'm not following you about what to try.
#10 | |
Im at 680rwhp with LPE kit and FIC850s pushing 100% My BAP should put me into a more safer 85ish%
