Old 06-02-2015, 06:01 PM   #1
ac223mal
Drives: car
Noweeds vs Shorties and/or High Flow Cats/Mid-pipes
Ive been researching this and am starting to go crazy.
My goal is to improve the sound of the car while hopefully helping performance without a tune. I have the fuse pull done & would like to keep the NPP exhaust. I am hoping to road course the car in the future, but the course here is set up in a parking lot with cones, and I haven't found free time to even watch it yet.
I was originally going to install noweeds, but I didn't like drilling a hole into the car and it seemed that there were issues with the diverters hitting a brace underneath (if anyone can advise, I only saw one thread addressing this issue).
By researching the noweeds, it seemed that the recommendation was to get HF cats instead. I liked this idea, because it seemed it was a simple bolt on. But then there is the issue with the HF cats failing (Z06Bryan had good results with his, but this was attributed to his tune). The JBA mid pipes seem to fail and I know Stephen12ZL1 had issues with his. Dynatech seems like they would be a good brand, but I can't find a mid-pipe with HF cats for the ZL1? I don't trust the shops down here to be able to fabricate what I need.
Shorty headers? I know they performance gains aren't high, but they keep me from having to tune. I would go ARH, but without a HF cat mid-pipe they wouldn't be very efficient.
So any help that could keep me from going crazy would help, especially if someone can point me in the direction of a reliable Mid-Pipe HF Cat that can withstand FI application.
ac223mal is offline   Reply With Quote
Old 06-03-2015, 11:58 AM   #2
ac223mal
Drives: car
Anyone?
Old 06-03-2015, 09:19 PM   #3
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
I got LT Headers (w/offroad connection pipes), cat delete and NoWeeds. The only ones that have brace issues that I know about are the Convertible Camaro's. Installed it all myself, the only issue I had was being called in during an HPDE event because I was 10db over the sound limit. Closed the NoWeeds and I was back on the track.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 06-03-2015, 11:20 PM   #4
thespymaster
thespymaster's Avatar
Anyone?
I run ARH LT's, Corsa Exhaust and QTP and at WOT, sounds like the gates of hell opening up...............
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 06-04-2015, 12:35 AM   #5
ac223mal
Drives: car
Thank you for responding. Long tubes are in the future once the warranty is up. The info on the NoWeeds is good stuff & if I cant get info on a reliable cat-less mid-pipe Ill probably go that route.
Thats what Id like to find w/o giving up the warranty...so maybe just the gates to purgatory for now. Thank you for replying.
Old 06-04-2015, 12:21 PM   #6
Drbormd
Drives: 13 F150 Eco 14 ZL1 650 RWHP
I run Kooks long tubes with high flow cats and NoWeeds. No matter how I adjust the pipes it does rub a bit on the brace. I am still trying to figure it out though and I won't give up. The sound is amazing...
Drbormd is offline   Reply With Quote
Old 06-04-2015, 12:31 PM   #7
ac223mal
Drives: car
Thanks, I had seen another post regarding the rubbing, that made me worry about it. I assume you have a coupe?
Old 06-04-2015, 01:36 PM   #8
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado
I'm looking at getting LT headers and no cats. I currently have the fuse pull on my NPP system. What am I looking at sound wise? For me, the louder the better.
ZL W0N is offline   Reply With Quote
Old 06-04-2015, 01:46 PM   #9
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
What mine sounds like ... Crank it up !!!
Old 06-04-2015, 04:04 PM   #10
ac223mal
Drives: car
That sounds real good!
Old 06-04-2015, 10:05 PM   #11
mmarx82
mmarx82's Avatar
All the audio is from inside the vehicle. On Cold start the NoWeeds in Closed position sounds just like the NoWeeds when open. It sounds good but I wanted more. There are 4 vids I made in total comparing all the configurations, here are two.
With NoWeeds Closed and just Headers w/Cat Delete
With NoWeeds Open and Headers w/Cat Delete
My build Thread
Old 06-06-2015, 12:48 AM   #12
Drbormd
yes mine is coupe..
Old 06-06-2015, 06:44 PM   #13
ac223mal
Drives: car
yes mine is coupe..
Thanks, I didnt put it together till now but your thread on the rattle was the thread I was referring to.
http://www.camaro5.com/forums/showth...exhaust+rattle
Old 06-06-2015, 11:38 PM   #14
mmarx82
mmarx82's Avatar
His NoWeeds install would just need to be adjusted. Loosen front and back clamps, twist the NoWeeds so that it lifts the OEM exhaust off the brace and re-tighten the clamps. That's no big deal.
My build Thread
