Born To Run
Drives: 2013 BRM SS/RS LS3 Join Date: Jul 2012
Latest Iphone update seems to have taken away functionality with the Mylink system?
Having a bit of a problem with this stupid mylink (agian) and Iphone.
My Iphone 5S won't connect to the car anymore for music or hands free calling, gives me an error message telling me to "Try again", at which point touching anything, even the volume knob, will cause the phone to disconnect. Just started happening after I updated my Iphone to 8.1, or 8.2, or whatever the hell apple is at now. anyone having a similar problem? Any way to fix it?
Just Lettin' the Night Roll... 2013 Blue Ray Metallic 1SS/RS Dual Mode Exhaust + Fuse Pull / CAI inc. CAI/ 1LE Strut Tower Brace/ ACS T4 Splitter/ SunRoof/ BA Audio/ Performance Shifter/ White Rally Stripes |
![]() ![]() ![]() ![]() Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
No problems at all with My 5s. After the last update I did have to delete the bluetooth and rediscover it though.
![]() Drives: The red one Join Date: Jan 2015
I don't know if iPhones have the same thing as Android but on my Galaxy S5 I went into the Bluetooth app settings and cleared the data and the cache. I didn't have to re-pair the device and it worked fine again.
![]() ![]() Drives: 2014 Camaro SS Join Date: Sep 2013
Nothing wrong with my iPhone 6 or 6 plus.
![]() Drives: 2014 Chevy Camaro SS Join Date: Oct 2014
Typically removing the bluetooth device from Mylink and removing Mylink in Bluetooth settings on your car. Then repairing will fix that.
Number of people killed by wolves last year... Zero
Number of people killed retrieving change from a Vending Machine.. Six |
#6 |
Typically when that happen , one can make it work again by start it over like it was a new unit , like said above
Erase each unit from each equipment ,mand pair it again , it should work fine from there |
#7 | |
![]() ![]() ![]() ![]() Drives: 2014 Summit White 2SS/RS M6 Join Date: Aug 2012
#8 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
I have done some iPhone programming with bluetooth. The iPhone "ID" is not fixed, so it may get a new one with an upgrade. This is why you need to reconnect the bluetooth services.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
