06-03-2015, 12:23 PM | #1 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Wheel Spacer for spare tire?
What size spacer/adapter do I need for a spare tire? 2" thick or is 1.75" thick wide enough?
This is to clear the brembo brakes. I have the 18" spare tire that came with the 1LS but of course it no longer fits with my brakes. I found a kit online for $275 with the tire and they offered to sell just the spacer for $75, this is from performancespare.com, but I found cheaper ones. Are these an OK brand? Or does anyone sell a single one for about $50 or less? I keep finding sets for $100-200 and I found a single is most often priced at about $85 Any recommendations are appreciated. |
06-03-2015, 05:33 PM | #2 |
SHKE BKE
anyone?
06-03-2015, 10:26 PM | #3 |
Drives: 2012 Inferno Orange 1SS/RS Join Date: Apr 2012
I have the performance spare one and it works perfectly. I would go with their spacer and lug nut kit. If you buy just the spacer from them, make sure it comes with the needed lug nuts to fasten it to the studs on the factory hub. The great thing about their spacer is that it is hub centric, meaning it will fit perfect with no wobble.
I bought the full kit from them after I bought my SS. Just note, if you go the spare tire route, if you ever have a flat rear you need to do the following: Remove the front tire, put the spare on there. Then move the factory front wheel and tire to the rear. That way the rear will sit the same height and you won't stress/damage the IRS setup. Last edited by Brandon_Lutz; 06-05-2015 at 08:53 AM. |
06-04-2015, 09:37 AM | #4 |
Drives: 2014 2SS/RS L99 Join Date: Nov 2012
I agree with Brandon, I just bought the full kit from performancespare.com and everything fits & looks great.
06-04-2015, 09:49 AM | #5 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
On Star has free towing. If you still have it.
06-04-2015, 05:49 PM | #6 |
SHKE BKE
06-05-2015, 08:00 AM | #7 |
Drives: camaro Join Date: Jun 2015
The great thing about their space is that it is hub centric, meaning it will fit perfect with no wobble.
