Old 06-04-2015, 08:03 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
lost clutch at a autocross
Clutch went to the floor and could not pull it back up. I did get it to work by just starting the car in gear and then just pulled the clutch back up. Made more runs with no issue. I would not be heat related at all because it being first run and not a long one.
Skylane765 is offline   Reply With Quote
Old 06-04-2015, 08:05 PM   #2
alan91z28
alan91z28's Avatar
Drives: 82,85,88,88,89,91 Camaro,88TA,87GN
are you just running the stock clutch master / slave and also just factory fluid?
alan91z28 is offline   Reply With Quote
Old 06-04-2015, 08:34 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I installed a spring kit from Lingenfelter because of the possible issues with this. I have heard of many C6 Z06 cars that have the dreaded "clutch pedal stuck on the floor". The return spring kit is simple to install and should prevent any possible problems with the factory return spring being less than adequate.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-05-2015, 12:06 AM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
No issue with the ZL1....I've been to two track days so far...
Mods:
Old 06-05-2015, 12:16 AM   #5
backeddy
Banned
Drives: 2011 Boxster Spyder (best car ever)
Simple fix, do my track day flush......1.5l of Castrol SRF and A mity vac........change it all out in 30 minutes
backeddy is offline   Reply With Quote
Old 06-05-2015, 06:17 AM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Hey John, just a thought...did you do the brake reservoir cap fix on your Z/28? I found that you need to remove the cap "spacer" so the OEM cap can breath during track events. Next time your pedal does not come up double check your brake fluid cap pressure by removing the cap. I bet you'll find it under pressure and by removing the cap your pedal will return to normal return position.
And yes, what backeddy said also...you need to bleed the brake fluid from the reservoir before and after each track event as well.
Mods:
Old 06-05-2015, 11:41 AM   #7
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Cool. Do the cars share the same setup? I don't recall.
Zslash28 is offline   Reply With Quote
Old 06-05-2015, 11:45 AM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
As stated, change out your fluid and that will help a ton.
Best regards,
Tyler
888-308-6007
Old 06-05-2015, 01:29 PM   #9
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
I do not think this is necessary after each event.
I had the same issue but mine gave little warnings long before the pedal went to the floor. Still do not know what it was but I suspect the oem fluid boiled in the clutch since we bled and put in srf in but failed to bleed the clutch at the same time.
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 06-05-2015, 05:05 PM   #10
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
I believe so....I'm almost 99.9% positive they share the same clutch pedal and reservoir set up.
You may be right buy it's a small thing to do to prevent this. Having your clutch not return when high performance track event would not be fun. A split second distraction can mean your into the wall ASAP depending on the course your on.
Just my .02
Mods:
Old 06-06-2015, 04:34 AM   #11
X25
X25's Avatar
Drives: '16 C7 Z51
I'd actually be against using a stronger spring since the issue is actually caused by contaminated fluid, and the stronger spring would hide it longer, and perhaps long enough to let the dirty fluid infiltrate the seals, which starts the one way journey to eventually having to replace the slave cylinder.
Replacing fluid often is helps quite a bit. Also, not that I claim OP has done it, but no launches with semi-engaged clutch on these cars, please : )
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 06-06-2015, 07:13 AM   #12
Stephen12ZL1
Drives: '21 ZLE A10
if you were at the track during a session with your pedal stuck to the floor, you would be "FOR" the accessory spring which will cure this problem. No doubt the fluid needs to be fresh & new, but this issue isn't caused by cruddy fluid. It is the design of the factory return spring under the dash that causes this problem. It happens so much that I personally didn't want to deal with this issue on track. I consider it a wise investment with fresh fluid also. I have personally seen 2 C6 Z06s and a Camaro at VIR with their pedal stuck to the floor with recently flushed systems. http://www.lingenfelter.com/mm5/merc...9#.VXLiQHD3arU
Old 06-06-2015, 10:08 AM   #13
Stephen12ZL1
Drives: '21 ZLE A10
the correct answer is "all of the above". read this:
http://www.superchevy.com/how-to/eng...ally-speaking/
Old 06-06-2015, 01:01 PM   #14
backtotintops
Drives: 14 Z/28 0#
interesting. thanks for the link stephen
