Old 06-05-2015, 09:12 AM   #1
Everest
Everest's Avatar
Drives: 2SS/RS L99 Rally Yellow Sun Roof
275/35-20 Front 315/35-20 Rear anyone have this setup?
I'm looking to get this setup but just wondering if anyone has had problems. traction or stability control going nuts? Or any other glitches?
275/40-20 is optimal for the front but I was told it will rub if I decide to lower the car later.
Any help would be appreciated. Spending some serious coin and don't want to @#$@ it up.
E
Everest is offline   Reply With Quote
Old 06-05-2015, 09:52 AM   #2
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
I'm 265/30-22 Front and 315/30-22 Rear
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 06-05-2015, 10:27 AM   #3
Everest
Everest's Avatar
ok cool that's pretty much the same ratio.
Old 06-05-2015, 07:58 PM   #4
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
E
275-35-20 is 27.6" tall
315-35-20 is 28.7" tall
you will have stabilitrac issues.
see here for recommended sizes.
http://www.camaro5.com/forums/showthread.php?t=62838
265-30-22 is 28.3"
315-30-22 is 29.4"
you will have stabilitrac issues as well. I bet you have 315-25-22 as those are 28.2 "
Its easy to figure out sizes that are not listed use the formulas below.
width x aspect % = sidewall height
multiply this times 2 then divide by 25.4 this will give you the total sidewall height in inches.
now add your wheel size to get the toatal height.
A 255/35 R20 tire would be
255 x 35% = 89.25mm (or 255 x 0.35)
89.25mm x 2 =178.5mm now divided by 25.4 is 7.03 inches.
7.03" + 20" wheel is 27.03" total height.
GVA 45TH 2SS is offline   Reply With Quote
Old 06-05-2015, 08:51 PM   #5
Everest
Everest's Avatar
Thanks GVA
I've read the chart made by Nine Ball. I've been speaking with CCW Wheels and they told me they've done this particular set up with no issues. and now I have chozn4service with the same ratio setup. and if he's running it, I would imagine he has no outward problems.
The revs per mile on my set up would be -3.9% difference between the two sizes and 1.1" difference in height. and Chozen's is 4% with the same height difference. I've heard if I keep it within 6% it should be good.
So I have different conflicting sets of information and I think the best way to really make sure is to find someone with the same set up. Or I can spend the dough and believe in CCW which has a great reputation.
Old 06-05-2015, 09:05 PM   #6
Installer.613
Drives: 2010 Camaro 2SS/RS , 1967 camaro SS
I'm running 275/40r20's up front on a 20X10.5 wheel and lowered with Eibach pro kit and have never rubbed.
Installer.613 is offline   Reply With Quote
Old 06-05-2015, 09:07 PM   #7
Everest
Everest's Avatar
ahhh they told me there was a chance of that happening with that tire which is why they recommend the 275/35. does the side wall look kinda big on the 275/40?
how much lower are you on the front? 1"
Old 06-05-2015, 09:21 PM   #8
Installer.613
Lowered 1"
Old 06-05-2015, 09:30 PM   #9
chozn4service
I'm lowered with Detroit Speed Engineering, 1" all the way around. No issues what so ever and I'm nicely tucked as well.
Old 06-05-2015, 09:41 PM   #10
Everest
Everest's Avatar
Installer, your stretching your front tire is that helping with the clearance? Is that why you have no rubbing?
nice wheels by the way guys!!
Old 06-06-2015, 12:40 AM   #11
MonsterV6
MonsterV6's Avatar
Drives: Chevrolet Camaro
20x10.5 all corners. 275/35 front. 285/35 rear slammed tucked in perfectly
481rwhp 436 rwtq on a Mustang dyno, BTR stage iv comp cam, Stainless power headers w/ highflow cats, G5CR intake, straight pipe, vmax throttle body, 6k hid fog & headlights, BMR strut bar, LG Motorsport coilovers Hurst short shifter, Elite catch can, Stillen splitter,cypher harness bar,
MonsterV6 is offline   Reply With Quote
Old 06-06-2015, 01:08 AM   #12
Everest
Everest's Avatar
thanks Monster looking for 315's on the rear though.
Old 06-06-2015, 01:47 AM   #13
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
looks Good!
VR Baron is offline   Reply With Quote
Old 06-06-2015, 11:43 AM   #14
SkunkJunk420
SkunkJunk420's Avatar
Drives: camaros
275/40/20 front and 315/35/20 rear PFADT springs (1.25' drop) NO issues!!!
SkunkJunk420 is offline   Reply With Quote
