Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros > 1st & 2nd Gen Marketplace
Old 06-07-2015, 06:14 PM   #1
Roto-fab 1
Roto-fab 1's Avatar
Drives: 16 Camaro SS w/ Roto-fab CAI
1st Gen Roto-fab LS3 Goodies!
Finally, a quality cold air intake system built specifically for your LS equipped 1967-69 Camaro! Now you claim the extra horsepower gained with a well designed cold air intake system that looks great and fits the car as it should. Thousands of 5th generation Camaro SS and Camaro ZL1 owners have installed a Roto-fab cold air intake systems due to the performance, sound, appearance and reliability. It only makes sense to put your trust in a company which already has the experience and expertise with the LS powered cars. Check out the benefits of our first generation Camaro cold air intake system:
*304 Stainless steel duct work in texture black or polished finish (4” OD)
*Aluminum air box which uses existing mounting points
*Air box lid with polycarbonate insert and “half turn” fasteners
*100% high gloss silicone couplers
*Lifetime serviceable air filter
*Optional MAF sensor mounting block
The Roto-fab cold air intake system for the first generation Camaro installs without drilling or modifying your car. The air box uses two existing bolt holes in the core support to anchor the front. For the rear we supply a longer bolt for your inner fender which, once installed, extends upwards to create a stud which is engaged by our rear mounting bracket. We use a 4” 90 degree elbow from the hump hose to the throttle body which provides the flexibility for small variations in motor location by adjusting the engagement in the silicone couplers. The air box face as well as the polycarbonate insert have a surface parallel to the factory diagonal support brace which further customizes this system to your first generation Camaro.
We plan to have this intake available later in June. In addition, we have expanded our line of custom LS3 engine covers for LS3 transplants. Look for a post on our engine covers later this week!
Roto-fab 1 is offline
