Old 09-06-2009, 09:55 PM   #1
ladysman07
ladysman07's Avatar
Drives: 2010 Camaro 1LT/RS
Winter tires & wheels for RS Camaro, smaller size then 20 inch mess up the odometer?
I have heard people talking about their winter tires/wheels....and how if they step down in size from the original 20's it will mess up the odometer readings for miles....is there any truth to this....i wanted to put on either 17 or 18 inch wheels with snow tires for the winter...thanks.
ladysman07 is offline   Reply With Quote
Old 09-06-2009, 11:46 PM   #2
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Rim size does not impact the speedometer/odometer readings at all. The overall tire diameter is what you need to be concerned with.
For example, the Camaro comes with 4 different rim sizes (18"-21") and 8 different tire sizes but they all have one thing in common - the overall tire diameter is right around 28.6"-28.7".
18" (LS, 1LT) - 245/55R18 = Diameter = 28.61"
19" (2LT) - 245/50R19 = Diameter = 28.64"
20" (RS, SS) - 245/45R20 & 275/40R20 = Diameter = 28.68" & 28.66"
21" (Option) - 245/40R21 & 275/35R21 = Diameter = 28.71" & 28.58"
Basically, when you are shopping for snow tires and wheels, it doesn't matter whether you buy 17", 18", 19", 20", 21" or 22" wheels, just make sure whatever tire you buy has a diameter/height of right about 28.65" and you'll be fine with your odometer/speedometer being accurate.
rolnslo is offline   Reply With Quote
Old 09-07-2009, 09:25 AM   #3
Cyber_Gray_Autobot
Drives: Camaro 2LT RS
If you want 18 inch rims for the winter, 225x60 will have the same overall size and will not mess up your speedometer or odometer.
I had a guy tell me that I would HAVE to buy 20 inch winter tires but they are very expensive and he was WRONG. There are many 18 inch winter tires to choose from.
Cyber_Gray_Autobot is offline   Reply With Quote
Old 09-07-2009, 09:07 PM   #4
ladysman07
ladysman07's Avatar
Looked on tirerack.com 4 tire/wheel combos 4 winter....overall diameter isnt something thats shown....I bet it wont be too easy to find out diameter.
Old 09-08-2009, 04:07 PM   #5
rolnslo
Rolling along...
rolnslo's Avatar
Overall diameter calculation isn't rocket science. Here's my explanation from another recent thread.
Originally Posted by rolnslo View Post
Tire diameter is calculated this way: (using 275/35R18 as the example)
275 = tread width in millimeters
35 = aspect ratio expressed as a percentage of the tread width (35% = .35)
R18 = rim diameter in inches
25.4 = conversion factor from mm to inches
Overall tire diameter = (((tread width * aspect ratio) / 25.4) * 2 ) + rim diameter
(((275 *.35) / 25.4) * 2) + 18 = 25.5787" tall
NOTE: ((tread width * aspect ratio) / 25.4) is the calculation to find out the tire sidewall height in inches
On an LT, you should be fine with an 18" rim. If you don't want a bigger gap than the stock gap, then you need to make sure your tire diameter is about the same as the stock 28.6" size. For a 19" wheel, a 305/40R19 would be about 28.6" tall. For an 18" wheel, a 275/50R18 would be 28.82" tall.
Old 09-08-2009, 04:57 PM   #6
mghawk57
Drives: 2010 Camaro
What about the Brembo brake option on the SS and 17" or 18" rims.Just asking!
mghawk57 is offline   Reply With Quote
Automobilemag.com: 2010 Chevrolet Camaro - Q&A Scotsman 5th Gen Camaro SS LS LT General Discussions 23 10-12-2008 01:13 AM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
