HELP!!! REAR TAIL LIGHT PROBLEM
Hi im new this camaro form, so plz excuse my foolishness
i live in Lebanon middle east, no real experienced mechanics here.. I have a camaro 2LT/RS 2013 i recently got a msg on the dash saying to check rear left turn signal light. So i checked & the left inner light was off, so i changed the bulb and couple of hours later it showed the same msg again, some problem.. i double checked if the bulb was correctly in, wires, the works.. Whats the problem and whats the solution, fuse or something?? dont want to go down to the dealer ship for something that i might be able to fix by my self.. Thanks any help would be appreciated |
Dazed &
Drives: matte blue 2014 z28(186) 2015 R1 Join Date: Jun 2013
do you have factory warranty? If you do just take it in they have to fix it.
D666MAN
Check lamp socket. Easy to replace and under $10 on Ebay.
They don't plug in backwards, so that's not it.
If the fuse blew, it would not have worked at all, to not working again. There is a short, if it keeps blowing bulbs. |
