Old 06-09-2015, 09:24 AM   #1
crowejim
crowejim's Avatar
Drives: 2015 2LT RS Coupe
I feel stupid
The other day, I apparently left the dome light on or something and drained the battery in my 2015 2LT. So, I figured I would put it in neutral and push it out of the garage so I could jump it from another vehicle. However, no matter what I did, it wouldn't come out of park (automatic trans). I tried turning the key to all possible positions and pressing the brake firmly. No luck.
So, is there a trick to this? Maybe an override button? I would hate for this to happen again and not be able to get close enough with another vehicle to jump it.
Thanks.
Jim
Hmmm... Possibly a mid-life crisis.
crowejim is offline   Reply With Quote
Old 06-09-2015, 09:27 AM   #2
dantemcc
Drives: 2017 1SS 1LE
Dont feel stupid, everyone makes mistakes. Dunno about the trick getting it out of park as i have a manual. It may be a safety feature of some sorts. I know my 08 Mazda 3 does the same thing. But I'm sure everything will work out just fine!
dantemcc is offline   Reply With Quote
Old 06-09-2015, 09:30 AM   #3
Dznyfn
Dznyfn's Avatar
Drives: 13 1SS Vert, 05 Tahoe Z71, 67 RS/SS
In my other auto cars, you have to go into the console at the shifter and raise/push the lock pawl if there is no power to the car.
Dznyfn is offline   Reply With Quote
Old 06-09-2015, 09:35 AM   #4
MLL67RSSS
Drives: car
Don't know how to get it out of park but:
A. Is car nose first in garage? Since your battery is in the trunk could you pull up a car close to the rear of the Camaro and jump it? Cables should be long enough. You'd have to crawl through the back seat to pull the emergency trunk release if battery is too dead.
B. Get a portable battery booster/starter and use if for power to see if that will get it out of park. You can connect it under the hood on the jump posts to get the trunk open also and not have to crawl through to pull the release.
Also I believe the BCM will kill any lights left on so as not to drain the battery.
MLL67RSSS is offline   Reply With Quote
Old 06-09-2015, 09:37 AM   #5
WoodBoss
"Old School"
Drives: 2010 2SS L99
You are better off getting someone to drive to you. Pushing your car with no power could be risky. Maybe invest in a jump starter box and keep it charged in the trunk if you continue to have problems.
WoodBoss is offline   Reply With Quote
Old 06-09-2015, 10:14 AM   #6
Mityguy
Drives: 2018 Hyperblue Camaro 1SS/1LE
Wish I could help but I drive a manual. But hey don't beat your self up! Those jump boxes are handy to have all the time if you invest now when you need it; you never know you might need it again!
Mityguy is offline   Reply With Quote
Old 06-09-2015, 10:30 AM   #7
TooCool5
TooCool5's Avatar
Don't feel bad, I got stranded in the driveway 2 days, because my key Ignition
chime got stuck on, when I tried to clean the cylinder it locked up!
There is all sorts of lock out features with no battery power.
I couldn't get my Ign key out when my battery was unhooked, turns out
there is a slot under the steering column for this.
Do what others said, either jump from rear, or just put a trickle charger on it.
Old 06-09-2015, 10:41 AM   #8
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
In your owners manual it states this too. Without the key in you can't just push the lever forward?
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 06-09-2015, 10:51 AM   #9
pickwithaustin
pickwithaustin's Avatar
Drives: 2011 Camaro 2SS/RS Convertible and:
Put one of these on every car you own:
http://smile.amazon.com/gp/product/B...A2U296R8AN80PO
Currently in my Garage:
2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i
pickwithaustin is offline   Reply With Quote
Old 06-09-2015, 10:59 AM   #10
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
Same here but I am looking at pictures of the Camaro shifter and I dont see one? maybe its located some where else? Weird most new cars you see the little piece you can pop out to unlock the shifter in case of loss of electrics.
trashmanssd is offline   Reply With Quote
Old 06-09-2015, 11:21 AM   #11
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
Like the other said, portable battery charger is your best bet.
JLSuperfly is offline   Reply With Quote
Old 06-09-2015, 11:30 AM   #12
seven
seven's Avatar
Drives: 2015 Camaro RS 2LT AGM
I had my jump started in my driveway and he used the terminal under the hood to do it. Try to jump it first where the car is. I used my free road side service with chevrolet and guy had a jump machine. It may not have been you. You could have bad battery. That happened to me.
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions)
seven is offline   Reply With Quote
Old 06-09-2015, 11:59 AM   #13
GrandAmGT
GrandAmGT's Avatar
Drives: 2010 1LT & 2016 Cadillac CTS V6
not sure if your garage is attached to a house or has electricity in it but you could buy a car battery recharger that you plug into a 120 volt AC wall outlet. I used to have a car I didn't drive much that I kept in a garage. The battery would discharge if I didn't run the engine periodically so I just recharged overnight and and a fully-powered battery the next day. It won't be as quick as a jump start but you don't have to move your car.
GrandAmGT is offline   Reply With Quote
Old 06-09-2015, 12:18 PM   #14
pickwithaustin
That is why they make the Battery Tender.
The PriorityStart! is, though, the best long term and most little known about solution. At a minimum, I'd run one on any older or modified car.
