Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 06-09-2015, 02:21 PM   #1
Jester06
Drives: 2013 White L99 SS
How strict is NOVA emissions with Hi-Flow Cats
Has anyone in the NOVA area had any problems with emissions testing that had Hi-Flow cats installed? I ask because I'm thinking about getting Stainless Works 3" Retro Chambered cat back with Hi-Flow cats, but i dont want to fail emissions. Any feedback would be helpful, thanks!
Current HP/Torque: 413HP/413 Torque
Current mods: Pfadt Tri-y Headers with Hi-Flow Cats, VMAX CNC Ported Throttle body, CAI intake by Cold Air Inductions, Apex Air Scoop/Washer relocation set, RX Catch Can, Stainless Works 3" retro Chambered cat back exhaust, Flex Fuel sensor, 3.91 gear ratio, BMR rear trailing arms, BMR Rear Toe rods
Future Mods: GPI's SS3 VVT cam, 3600 stall triple disc torque converter, Fast LSX 102mm throttle body
Jester06 is offline   Reply With Quote
Old 06-28-2015, 09:51 AM   #2
Thawilster
Thawilster's Avatar
Drives: 2011 Black 2SS/RS L99 Vert
Bump! Great question ... I'd like to know also.
Thawilster is offline   Reply With Quote
Old 06-28-2015, 10:12 AM   #3
motorhead
From what I've heard and read, many hi flow cats pass the test, but if your shop does a visual you will most likely fail. To me though any rational mechanic would let it go if it passes the test. Who knows though. Why not ask a testing facility before you purchase them?
Old 06-28-2015, 11:03 AM   #4
IMPERIALBLUE2SS
Drives: 2010 imperial blue LS3 M6 2SSRS
Don't ask anything it raises suspicion and you will definitely fail. Been there done that. If it passes sniffer they really won't be to concerned with visual.
IMPERIALBLUE2SS is offline   Reply With Quote
Old 06-28-2015, 11:10 AM   #5
motorhead
I agree, I should have also wrote to ask a place that you don't actually take your car to.
Old 06-29-2015, 07:12 AM   #6
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Have many customer in the area, with long tubes and high flow cats that pass the emission test, so i don't see a problem. Although it will take a few drive cycles to it to go into the reediness test,
Let us know if you need any assistant or any other question give us a call
540-439-3737 Broadview Auto
1fast is offline   Reply With Quote
Old 05-01-2018, 08:51 PM   #7
Baggerjack
Baggerjack's Avatar
Drives: 2014 Camaro 2SS/RS/1LE
Do those cars have a tune? I will be adding LT and high flow cats soon, but don't want to do the tune right away.
Crystal Red Tintcoat, NPP, Recaro Seats, Sunroof and SLP Skip Shift, ZL1 rockers, TSP Stage 4 "F35" cam, PRC 260cc heads, GPI radically ported LS3 Intake, K&N CAI and JDP Motorsports Stage 2 Clutch Reservoir Kit, TSP Longtubes, off road connectors and high flow cats, aFe POWER Solid Subframe mounts, Brembo 6 piston calipers and two piece rotors
Baggerjack is offline   Reply With Quote
Old 05-16-2018, 09:48 PM   #8
Tom68Goetz
Drives: 2011 2SS/RS M6
i was at a shell station in Alexandria getting an emission test on my 2010 Sierra, the first the thing the mechanic did was get on the floor and look to make sure I had a cat installed even before the sniffer was hooked up.
Tom68Goetz is offline   Reply With Quote
