Old 06-11-2015, 10:27 AM   #1
jolson63
Drives: 2014 camaro ss
BACKFIRE
Has anyone in countered an occasional backfire. When this happens the traction control service light comes on. The tachometer quits working and the check engine light comes on also. The code in the ECM is CRANKSHAFT POSITION SENSOR. The GM dealer is stumped also. Any advise would be helpful.
jolson63 is offline   Reply With Quote
Old 06-11-2015, 11:57 AM   #2
Lndryguru
Drives: 2013 Camaro 2SS/RS
i would try disconecting the batterie over night or see where the sensor is and replace it yourself could be the computer is acting goofy.
2013 Camaro SS Victory Red/Black Stripes
Lndryguru is offline   Reply With Quote
Old 06-11-2015, 12:01 PM   #3
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
If it is a bad sensor, they should replace it under warranty. Why is the dealership stumped?
Old 06-11-2015, 12:18 PM   #4
jrisebo
jrisebo's Avatar
Drives: 2011 Camaro RS "Bumble C"
Hope its not the same problem they had back in the mid 90's with crankshaft sensors, they caused rough idle, no starts, etc.
jrisebo is offline   Reply With Quote
Old 06-11-2015, 02:07 PM   #5
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
Did the dealer try replacing the crank sensor? If they didn't and they are stumped I would try a new dealer...
JR 1 is offline   Reply With Quote
Old 06-11-2015, 02:43 PM   #6
beuben
Drives: 2011 2SS/RS M6
I had an issue with mine- the wires were loose where they were crimped into the connector for the crank position sensor. They were loose enough so that the inop tach, service stabilitrak, hard start and rough running conditions were constant from the moment it happened, but I could see an intermittent problem persisting if the wires were just barely loose. Mine only had about 600 miles on it at the time and suddenly came on when I pushed the clutch in while in first gear in bumper to bumper traffic.
beuben is offline   Reply With Quote
Old 06-12-2015, 09:12 AM   #7
jolson63
I am not sure what the dealer is doing. They are working right with GM now and they haven't updated me at all. Usually when the crankshaft sensor goes bad the engine just shuts off I think and then it will start in 30 min or so. It seem to start when I put the cat back Borla exhaust on. That shouldn't have anything to do with it. Lots of cars come stock with that exhaust on them. Thanks for the replies!!
Old 06-12-2015, 09:38 AM   #8
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
I had one go out on my 2001 GMC truck and it never did refire. They had to replace it at the dealership and relearn the computer to read the proper engine crankshaft position. It only took an hour to fix it once they got started, but I was stuck on the side of the interstate in 105 degree Texas heat for 3 hours waiting for them to come get it on a Sunday afternoon.
The Bird is the word!
Old 06-12-2015, 09:57 AM   #9
jolson63
ya, I had one go out in my 7.3 diesel F350. It just quit, but it started a few times after 30 min or so. And yes I was stuck in -15 in January in MN. Burr! lol
Old 06-12-2015, 11:41 AM   #10
jolson63
I wonder if the ECM needs to be retuned for the new Borla exhaust? Any input on this would be greatly appreciated.
Old 06-12-2015, 06:35 PM   #11
MBS
MBS's Avatar
Drives: 2010 rs 2lt
All cars can backfire , Its normal I wouldnt worry about it unless it happens constantly
MBS is offline   Reply With Quote
Old 06-12-2015, 06:38 PM   #12
Angrybird 12
The only time my Camaro has backfired is when I was in manual mode and hit the rev limiter.
Old 06-12-2015, 06:48 PM   #13
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
3 hours in 105 degree heat? ... Wow.. that must have sucked! I bet you were cooked.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 06-12-2015, 06:53 PM   #14
Angrybird 12
Yep and not one person stopped to help....... I was used to the heat having worked in a chemical plant but my wife was a different story. I was afraid she was going to have a heat stroke... We did have a cooler with water and ice in it...mostly water by the time the towtruck came.
