Old 06-11-2015, 11:01 AM   #1
dantemcc
Drives: 2017 1SS 1LE
Question for my fellow manual drivers out there
I'm curious if its the same on all Camaro's or if they vary from car to car. Where's your clutches engagement point? For me, if you think of a clock, 12 being all the way off the clutch and 6 being all the way to the floor, mine is at 1. I cant for the life of me understand why its that high up. I almost routinely kill the car because of where the bite point is. Even having Bee for 7 months now, I havent gotten fully use to it. Well, seeing is how I'm rarely there to drive him, may be a large reason why.
Just curious as to where other drivers bite point is at in their car.
dantemcc is offline   Reply With Quote
Old 06-11-2015, 11:04 AM   #2
EmeryZ28
EmeryZ28's Avatar
Drives: 2011 Camaro 2SS/RS LS3
I think maybe 1/3 of the way depressed it engages?
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
EmeryZ28 is offline   Reply With Quote
Old 06-11-2015, 11:09 AM   #3
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
I think mine engaged at somewhere around 1/4 to 1/3 depressed. My bigger gripe is was the clutch travel between no engagement and fully engaged. For the majority of the pedal travel nothing happens then when it starts to engage there was only the slightest bit of travel until it was fully engaged. It took a lot of getting used to.
JR 1 is offline   Reply With Quote
Old 06-11-2015, 11:12 AM   #4
dantemcc
I understand what you mean. Getting out of first and into second is never a smooth and easy transition. I've tried as many different techniques from shifting from first to seconds as I know and none of them work. I cant get it to go completely smooth at all. There's always that little jolt once I come off it regardless of whatever rpm's I'm at. Reve matching doesnt do a thing either. I dont get it.
Old 06-11-2015, 11:14 AM   #5
Spec
Drives: 2010 Camaro 1SS LS3
Yep, that... even going back to the 2010... the clutch engages pretty high up.
Spec is offline   Reply With Quote
Old 06-11-2015, 11:15 AM   #6
DFWZ28
DFWZ28's Avatar
Drives: 2010 SS
my release point is very high as well...takes a while to get used to it. as far as the shift from 1st to 2nd, low rpm's and a smooth foot on the accelerator will take car of the jolt. that also takes a while to get used to.
DFWZ28 is offline   Reply With Quote
Old 06-11-2015, 11:15 AM   #7
Jasper
Jasper's Avatar
Drives: 2011 Summit White Camaro SS (LS3)
Took me a long time to get used to it but I'm new to manual as well. I'd say I've been driving for 5months total now between last season and this one. I no longer stall it but do notice that the engagement distance is quite short (off and then suddenly on). So the biggest thing I had to learn was to just be more gentle and slow with it. At first it helped to keep my heel on the floor and just pivot my foot and let the pedal slide along the bottom of my show so I could control it slower. Now my leg is strong enough to move it right.
BTW, my dealership buddy told me that there was a TSB for our pedal. Mine was not returning to the full back position after engaging it sometimes and can wear the clutch. So they change it out with the ZL1 pedal as a fix. As soon as I got it back, it seemed easier for me to engage it for some reason.
J
Jasper is offline   Reply With Quote
Old 06-11-2015, 11:18 AM   #8
NTENSITY
NTENSITY's Avatar
Drives: 2015 Camaro 2SS 1LE Package
Ugh! Same here, glad I am not the only one, going from first to second is a pain in the a$$. I purchased the Ram Hydraulic Pedal Adjuster kit so I can adjust the engagement point of the clutch and reduce the travel time. I haven't installed it yet, but looking forward to it!
NTENSITY is offline   Reply With Quote
Old 06-11-2015, 11:19 AM   #9
Bassment
Drives: 2016 Red Hot 2SS M6
it's so you can switch gears fast. The further you have to push the clutch to engage it, the longer it takes to complete the gear change.
Bassment is offline   Reply With Quote
Old 06-11-2015, 11:31 AM   #10
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
I just dump the clutch everytime
Homeless Man is offline   Reply With Quote
Old 06-11-2015, 11:35 AM   #11
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
^ this is the correct answer.
Old 06-11-2015, 11:37 AM   #12
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
Mine sometimes clunks between 1st & 2nd but not always. I find that once the fluid temperatures are up she's smooth as silk. As you guys are all saying; it takes some getting used to - especially as the stick is in my right hand & not the usual left in the UK (cos as you guys know- y'all drive on the wrong side of the road over there.......)
Yellow 1 is offline   Reply With Quote
Old 06-11-2015, 11:49 AM   #13
DeeLight
DeeLight's Avatar
Drives: 2010 Camaro 2LT RS Red Jewel Tint
It had been years (17) since I had driven a stick, and the last car was a 4 cylinder nissan sentra. I've been starting in 2nd gear lately, unless I'm on a hill (after reading some suggestions on the forum). Maybe you can try doing this to avoid cutting off or jerking. You will have to give it just a little more gas, but it beats the embarrassment of cutting off at a stop light for me.
DeeLight is offline   Reply With Quote
Old 06-11-2015, 12:25 PM   #14
Trip
Trip's Avatar
Drives: 2015 White RS 2SS 1LE
Yeah, the engagement point is up pretty high on the pedal travel on mine too, takes some getting used to. If I'm getting a lot of jerky shifts, I'll try to only depress the pedal a little bit, instead of pushing it all the way to the floor, to change gears. It actually seems to help to make things a little smoother.
Trip is offline   Reply With Quote
