Old 06-11-2015, 12:48 PM   #1
Bluedevil1198
Bluedevil1198's Avatar
Drives: 2017 RED HOT SS
Installing fronts brembo calipers to the rear
Does anybody know if i can swap front Bremobo calipers to the the rear .
The rear currently has Brembo calipers.But it is the smaller 4 piston calipers .
I have an extra set of Brembo calipers , and i was wondering if i can do the rear swap without too much modifications !
Bluedevil1198 is offline   Reply With Quote
Old 06-11-2015, 12:52 PM   #2
JusticePete
Drives: Camaro Justice
It is possible to fabricate brackets and get them mounted. The problem is brake bias and ABS calibration. It would require a brake bias adjustment in the ABS calibration which we do not have access to. There would probably be hydraulic issues as well.
Long story short, find a new home for the orphaned 6 pot front calipers.
Old 06-11-2015, 01:02 PM   #3
Bluedevil1198
Great info JusticePete , i guess i will be leaving them the way they are .
I was going to put them on it it was a direct bolt on.
But after what you have just told me , i will be keeping them they way they are .
Yeah , i would probably just end up selling the extra set of calipers i have .
Thanks again for the info !
