Old 06-12-2015, 10:19 AM   #1
CyberGreyConvertible
Dunder Mifflin Inc.
CyberGreyConvertible's Avatar
Drives: 2012 2SS/RS Convertible
Which do you guys use: Floor Jack or Ramps?
So, I'm going to change the oil in my car within the next 2 months or so, and I need a way of accessing the oil drain plugs and everything obviously. Do you guys use floor jacks to lift the car or do you guys use ramps? I was thinking about going with ramps, as they seem a bit easier, but they get a bit pricey.
I appreciate all input,
Thanks!
CyberGreyConvertible is offline   Reply With Quote
Old 06-12-2015, 10:23 AM   #2
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Jack works just fine...
kmarshall2121 is offline   Reply With Quote
Old 06-12-2015, 10:23 AM   #3
M0dnar
Drives: 2015 Corvette 3LT with Z51
Deadlifts
M0dnar is offline   Reply With Quote
Old 06-12-2015, 10:24 AM   #4
Ron_MA
Ron_MA's Avatar
Drives: 2014 AGM Trifecta Tuned V6
Jacks 100% just take your time and be safe
Ron_MA is offline   Reply With Quote
Old 06-12-2015, 10:48 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I assume you mean jackstands and 6ton units work well.
Ramps would be more convenient sometimes, but jackstands are much more versatile.
Never get under a car just supported by a floor jack. Seals blow and even with a slow leak you can find yourself trapped if you're under there too long.
Old 06-12-2015, 10:50 AM   #6
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Ramps have an angle- of- approach- issue with these low vehicles. It can be done, but you'll need to place 2X4s or blocks of some sort in front of the ramps to keep from ripping up your chin spoiler/ splitter.
Floor jack is generally easier... but don't forget your jack stands. Many years ago, I thought them unnecessary, and performed a brake job on my Cutlass, sitting with my legs under the car (hey, I was a careless youth)... I trusted the jack. At one point, I stood up (did not even touch the car in doing so), stepped back, and, "BAM!" The jack spontaneously failed, and dropped the car to the ground. I missed having a double leg- ectomy performed by a few seconds.
Pardon the lecture, I just feel the obligation to preach it when I can.
Scalded Dog is offline   Reply With Quote
Old 06-12-2015, 10:51 AM   #7
Scalded Dog
Drives: 2011 1LT
(I see that CamaroCracka beat me to the jack stand lecture...!)
Old 06-12-2015, 11:07 AM   #8
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
I use ramps for oil changes and such. I use a floor jack and jack stands for rotating tires.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 06-12-2015, 11:10 AM   #9
SPCBA
Drives: pleather and Chiclets
Both, can't get a jack under my car without first using ramps
SPCBA is offline   Reply With Quote
Old 06-12-2015, 11:15 AM   #10
Tenring
Tenring's Avatar
Drives: 2015 SS/RS M6 Commemorative
Same here
Tenring is offline   Reply With Quote
Old 06-12-2015, 11:16 AM   #11
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
I have ramps that I use for my truck and work trucks and family cars I do but the Camaro wont make it as the ramps are to steep and the front will hit first. So I jack up one side and put tires on the top of the ramp repeat on the other side now my ramps are under it like normal and I can move the jack out and wheel around on my creeper. Then just reverse the process to get them out jack up remove ramp lower it to the floor. Safe and easy. I would buy race ramps with the right sloop if it were daily driver. I only have to do it once year.
trashmanssd is offline   Reply With Quote
Old 06-12-2015, 11:18 AM   #12
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
I'm lowered in front and have a splitter. Just buy the right ramps and you don't need to mess with blocks. I have the long Race Ramps that I used for my trailer. Since I have a custom belly pan, jacks don't work for me. I like to place the jack on a frame rail and not the underbody. Race Ramps are pricey though, believe mine were over $250 discounted.
bannonm is offline   Reply With Quote
Old 06-12-2015, 11:22 AM   #13
solo3445
solo3445's Avatar
Drives: My SS2................
race ramps are the best...
solo3445 is offline   Reply With Quote
Old 06-12-2015, 11:36 AM   #14
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 2018 Colorado
Never get under a car just supported by a floor jack. Seals blow and even with a slow leak you can find yourself DEAD if something goes wrong.
Fixed. Either work I use ramps for oil change.
molsonbrador is offline   Reply With Quote
