Size 315 tire in the rear?
Hey guys is it possible and is it good/bad to run a 315 in the back? And do i run a 35 or 30 profile?
I have been running 20x315 35 on rear now for awhile. I love them and no issues.
![]() Drives: Camaro ss 1le Join Date: Jan 2014
I've seen cars in here runs as far as 335 and no issues
![]() Drives: 2018 ZL1 A10 Join Date: Feb 2012
My next rear tire will be a 315/35-20. I don't like the blown out look of the 285/35-20.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
I'm sure it will work ,but from what I understand the stock size was to make it handle better , not to look better. But since I have never had any experience with different size rear tires on this car I would have to defer to people who have driven both on a track/road course on this .
OLD GUY FLYING FAST AND LOW
#6 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
You'll mess up the balance and therefore the handling. But if you don't care then go right ahead. The rears do have a lot of wheel well gap and it can be a visual turn off. Other threads have discussed this issue.
off topic: I have noticed 315/35/20 on the new BMW x5. Dunlop sports. For a soccer mom SUV it looks pretty d*mn good from the rear.
#7 |
![]() Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
I have 315/35's and don't have any issues with them. They hookup a lot better than the stock ones. That's just comparing them to my dad's 1LE who still has stock tires on it.
#8 |
![]() ![]() Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
I'm going with 305/35/20 MT ET Streets II for my next tires.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here |
#9 |
![]() Drives: 2010 1SS Join Date: Jan 2013
315/35/20 will work with absolutely no issues at all as long as you go with 43 offset. Plenty of people run with that. I have 275/40/20 w/35 offset up front and 315/35/20 w/43 offset in the rear, plus lowered 1" on all corners. ZERO ISSUES.
#10 | |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
SKIPPY
WHAT he said<<<< only my cars not Lowered <<![]()
#11 |
![]() Drives: 2014 Camaro 1LE Join Date: May 2015
I am thinking about doing 305 for the rear. Question for anyone that has larger rear tires: do you have your speedometer adjusted for the increased rotating diameter? Is tuning the only way to do it?
#12 |
Banned
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
just avoid the track with that setup, you will have a tendency to plow(ie understeer) through the corners as the car will not rotate correctly......
#13 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Good or bad depends on what you are trying to accomplish.
For looks only. Go for it with a 315/35/20. The OD of the tire is about .9" taller than the stock 1LE 285/35/20 so the back of the car will be just a hair under .5" taller. If you want to carve canyons or track the car this is a bad choice as the car will not rotate and will actually understeer more as mentioned above. I have had the 285/35/20, 275/40/20s, 305/30/19, 325/30/19 and now 305/35/19s on my 1LE just to play around with sizes and feel. I say this because if you are going for traction off the line compound and brand is more important than width. My current 305/35/19s (on all 4 corners) launch from a dig better than even the 325/30/19 Goodyears did and better Way better than stock. So much so I have surprised a couple Friends in GTRs not in launch mode as they didn't think they needed it.
#14 | |
I want the best width for launching. |
