![]() ![]() Drives: 2010 2SS Join Date: Sep 2012
1le strut package
Any vendors do just the struts and mounts? I cant find anything.
Gmpartsdirect sells the front for 75 bucks a piece. This seems like the way to go for staying at stock height, cost and minimal track time. Also will they work with my fe4 rear conversion and front bmr sway and endlinks?? Thanks!
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
