Old 06-15-2015, 02:43 AM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
what parts do i need to re-build brembo calipers?
Brembo Front Caliper Dust Shield Rebuild Kit part # is: 89047722
Brembo Front Caliper Piston/Seal Rebuild Kit part # is: 92244294
Brembo Rear Caliper Dust Shield Rebuild Kit part # is: 89047739
Brembo Rear Caliper Piston/Seal Rebuild Kit part # is: 89047731
So far this is what ive come across. Is there any more that i will need and do these numbers match up correctly to what i will need to send with my calipers when i have them powdercoated?
Nighthawk89 is offline   Reply With Quote
Old 08-14-2016, 03:36 PM   #2
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
I don't understand why a rebuild kit is like a unicorn for us! Must have something to do with sponsors on here. I've searched for years looking for one. There has to be an OEM one somewhere.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 08-14-2016, 08:33 PM   #3
Nighthawk89
I couldnt agree more when i did the caliper powdercoating i was lost.. I ended up purchasing from Rockauto. Mike the powdercoater was really informative with which to buy and where from (rockauto). If you try to call direct to a dealership parts, they are unsure and unable to give a direct answer.
Old 08-21-2016, 07:31 PM   #4
OmniCamaro
US Veteran
OmniCamaro's Avatar
Brembo Front Caliper Piston/Seal Rebuild Kit part # is: 92244294--need 2
Brembo Rear Caliper Piston/Seal Rebuild Kit part # is: 89047731 need 2
I'm going to add the necessary bolts to your list. It's a good idea to replace them.
Front-11570788--4each
Rear-11515781--4each
Still verifying the dust boots, will post back when I've confirmed they are correct.
Old 08-21-2016, 07:44 PM   #5
JusticePete
Drives: Camaro Justice
Google '2010 camaro ss caliper rebuild kit' for a quick listing.
Old 08-21-2016, 10:53 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
If you have the 6 piston read post 3 and 108 for 6 piston vented piston and seal kit.
http://www.camaro5.com/forums/showth...=418667&page=8
Orange Krush II
Old 08-31-2016, 02:20 PM   #7
OmniCamaro
US Veteran
OmniCamaro's Avatar
As of right now I'm going to reuse the boots. If that changes and I purchase some I'll post back here. Thanks for the thread OP
Sent from my iPad using Tapatalk
Old 01-27-2017, 06:44 PM   #8
OmniCamaro
US Veteran
OmniCamaro's Avatar
I ordered the Carlson parts (2ea. for front & back). Comes with the dust boots, seals and bleeder covers for one caliper. Consider that when ordering.
http://www.rockauto.com/?carcode=1504749&parttype=1720
Old 02-18-2017, 04:28 PM   #9
OmniCamaro
US Veteran
OmniCamaro's Avatar
I'm updating on the Rockauto parts, DO NOT GET THE FRONT's there! I think the picture speaks for itself. I had 4 orders of them and had 2 'decent' seals out of the 16! Refund in process.
Old 02-18-2017, 04:36 PM   #10
OmniCamaro
US Veteran
OmniCamaro's Avatar
I also now have this. Sure wish I'd had this a long time ago!
Parts breakdown of the front calipers. You're welcome!
Added the rear breakdown as well.
Old 02-18-2017, 05:29 PM   #11
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 Chevy & 2021 1SS/1LE manual
yeah the carlsons are crap for sure. i tried the centric and they seemed way better.
JOHNSONROD is offline   Reply With Quote
Old 02-18-2017, 06:10 PM   #12
hammdo
'It's an experiment'
hammdo's Avatar
Can you get the image for a ZL1 fronts ;o)?
Thanks for this one!
-Don
747 RWHP 794 RWTQ
Old 02-18-2017, 06:35 PM   #13
OmniCamaro
US Veteran
OmniCamaro's Avatar
-Don
What year? And if you pm, or post, me your last 8 digits of your vin I can definitely get it.
Old 02-21-2017, 03:33 PM   #14
OmniCamaro
US Veteran
OmniCamaro's Avatar
Verified OE 'bleeder screws' with caps--GM P/N-25900782
These are ACDelco parts, straight from Italy/Brembo. This part number will get you 1 caliper or 2ea. screws with caps.
