Old 06-15-2015, 07:35 AM   #1
Camarotobeornottobe
Drives: 1LE
1LE Brake Noise Question
So, I have to turn the wheel pretty hard when I back into my garage.
I have noticed that if I have the brakes MILDLY depressed sitting still, and then I turn the wheel in either direction to the lock position, the brakes make a groaning sound right before I reach the end of the steering, i.e. with the wheel approaching the most extreme spot. I can even wiggle the steering wheel back and forth in that area and get it to continue to make the noise. If I am completely off the brakes, or I hold them down hard, everything is quiet.
With the brakes not all the way depressed, am I just hearing the rotors trying to move slightly (against the brake pads) at that extreme steering position, and these "track" brake pads making noise in protest?
Camarotobeornottobe is offline   Reply With Quote
Old 06-15-2015, 01:59 PM   #2
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
Check your lug nuts to make sure they are all tight. I'm assuming you have the stock wheels and brake pads?
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
Old 06-15-2015, 03:12 PM   #3
Camarotobeornottobe
Drives: 1LE
Yep, all stock. It's kind of the same sound I hear from my wife's Dodge SUV under similar conditions -- kind of a creeking, moaning, "complaining" from the brakes . . . just much louder on the Camaro. Like I said, I can't replicate the noise if I am off the brakes when I do it, or if I press firmly. It's only in the middle ground.
I'm pretty sure the lugs are tight -- I use a torque wrench to ensure they are exactly where I want them. But, I'll check just in case.
Old 06-15-2015, 04:08 PM   #4
markgws6
markgws6's Avatar
I'll try doing this later and see what happens. I do not recall hearing such a noise and I have racing brake pads on the fronts.
(1 of 43)
Old 06-15-2015, 04:29 PM   #5
Camarotobeornottobe
Drives: 1LE
Thanks, the conditions in which it happens (sitting still, brakes mildly depressed, turn wheel to lock position either right or left) are not something you would be in frequently, so it doesn't surprise me that I haven't gotten much response.
Old 06-15-2015, 04:35 PM   #6
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Pretty certain it is caused by additional force of the tires upon the wheels transferring through the rotors and calipers while steering is at an extreme steering position.
Tried it with my 13..got same thing...tried it with Trans Am...same thing.
It feels like a grrrr grrrr with slight shuttering felt when releasing brake?
In essence...my theory is that while straight line there is equal distance between pistons to pad to rotor...when extreme turn outside that of normal driving, the piston distance on one side of the pad is greater than the other causing one pad to have no grip and the other pad to have excessive grip causing a higher pressure of one pad on each wheel on both sides.
Or it could be from the massive grip these tires have transferring through...
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 06-15-2015, 05:44 PM   #7
Camarotobeornottobe
Drives: 1LE
Bansheee, interesting theory. I love this forum when ideas are kicked around.
Yea, the "grrrrrr" is probably an accurate description. Slight shuttering, but very faint. The sound I'm talking about only happens while moving the steering wheel near that lock position, not holding it still. So, the car would be stationary, put your foot on the brake mildly, bring the steering wheel to the lock on the left or right, and then wiggle the steering wheel back and forth about a 1/4 turn -- then the sound is consistent. If you completely release the brake or hold the brake pedal down firmly, the sound will NOT replicate. That what you heard?
Old 06-15-2015, 06:16 PM   #8
Banshee
Banshee's Avatar
Try wetting down your garage floor or wherever you can replicate the noise....see what you come up with.
Just a theory...
Old 06-15-2015, 10:37 PM   #9
Camarotobeornottobe
Drives: 1LE
Okay, I figured it out, if anyone cares
If you turn all the way to the right with the brakes applied lightly, the noise comes from the right front tire (inside/front). If you turn left, it is from the left.
I had the wife do this for me while I listened standing close to the wheels. I guess when the wheel is turned very sharp (all the way), it wants to move the inside wheel just slightly even though the car is stationary. In doing so, the brakes are barely grabbing, thus making that groaning noise you can get sometimes.
If you hold the brakes hard, it holds tight and doesn't allow the wheel to move -- thus no noise. I was able to replicate it in my wife's car, it just wasn't near as loud. The 1LE is probably louder cause of the thick tires and grabby brakes -- perhaps even the camber of the inside wheel causes more "movement" at that sharp turn angle. Since you can actually feel the front of the car raise at that sharp steering point, I'm betting on the camber exacerbating the sound.
When I put carpet pieces under the tires, it had no effect, so it wasn't a function of the grippy tires only, per se.
Old 06-16-2015, 01:54 AM   #10
Banshee
Banshee's Avatar
Sweet!
Another gremlin bites the dust.
Old 06-16-2015, 12:42 PM   #11
markgws6
markgws6's Avatar
Glad you figured it out as I've not had the chance (or memory) to test it yet. I try not to turn all the way to lock while a car is stationary though for fear of damaging something.
(1 of 43)
Old 06-16-2015, 01:27 PM   #12
Camarotobeornottobe
Drives: 1LE
Thanks, in case it is not clear what I'm hearing, you know when you're stopped on a decline and let off the brakes just enough to let the car inch forward? The brakes make that slight groan noise as they are released. You are hearing the rotors against the pads. This is the same thing, only it does it while sitting perfectly still and only in the front/inside wheel at that extreme turn.
I just wish I could find somewhere where it is explained WHY the wheel is moving against the brake pads like that, i.e. the "physics" of why turning it that hard causes the inside wheel to rotate slightly (unless you hold the brakes firmly). Even Google has its limits
Old 06-16-2015, 09:20 PM   #13
Iroc Drew
Iroc Drew's Avatar
Drives: 2015 1LE 2SS/RS CRT NPP AYZ NAV SUN
Could be the strut tower brace keeping things tight. Just my 2 cents.
1989 IROC Z L98.
2015 Silverado LT.
2015 2SS 1LE.
Iroc Drew is offline   Reply With Quote
Old 06-29-2015, 11:34 AM   #14
USMUCL
Drives: 2021 Camaro 1SS 1LE
I bet it is the natural sound from the brakes and the tight suspension. No worries.
USMUCL is offline   Reply With Quote
