![]() Drives: 45th Anniversary owner and 72 Camar Join Date: Apr 2014
Mounting niche apex
Rims and tires due to come in any day now, is there any thing I need to due to make them fit properly. ?.I have already swapped front break pads. Will rear break cable need to be tied back , etc. 10.5 all 4 corners 275,305.....thanks
Been on hunt for wheels and tires, haven't had much luck with online companies answering questions. Where did you get them?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
Not enough information. The actual tire width is only part of the equation. Wheel size and the backspacing also come into play.
Assuming you stuck with 20's or even 19's, brake pads won't matter. |
Ordered everything from Best Wheel Deals in Florida...
Ask for Jon. I did get everything mounted yesterday and no issues...here is link. http://www.camaro5.com/forums/showthread.php?t=412837 |
