Old 06-15-2015, 10:33 AM   #1
khanh
Drives: 2012 45th anniversary V8 LS3
Suspension advice
Hi,
I have done some suspension mods but I still feel that it is not what I wanted. My mods are listed in my signature.
My problem is that I feel that car is so heavy and have still much bodyroll in corners. I set my sway bars to second hole.
What do you suggest? I don't want to waste money on some mods which won't help me.
My brother have stock 335i cabrio which is even heavier than my ss. It stick to the ground like glue and have no bodyroll in corners.
Thanks.
performance:
SW LT headers, SW 3" retro chambered exhaust with HF cats, CAI intake, Elite catch can, Jre tune.
suspension:
zr28 wheels, Pfadt ZL spec sway bars, Pfadt adjustable front end links, Pfadt trailing arms, Pfadt toe rods, BMR rear cradle poly bushings, Pedders front radius rod inserts.
audio:
front Hertz hsk 165.3, rear Hertz dcx 690.3, Helix P8W woofer, amp ipaul 4300, amp Carpower HPB 602, STP isilver sound deadening (doors, trunk, rear deck, under rear seats).
exterior:
SPL like splitter, red painted calipers, zl1 spoiler, 1le diffuser with quad tips, zl1 upper grille.
khanh is offline   Reply With Quote
Old 06-15-2015, 12:30 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Try adjusting the sway bars. Coil overs will help also. Lower the center of gravity, higher spring rate, and adjustable dampening will all help fight body roll.
Old 06-19-2015, 12:07 AM   #3
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Adjust the sway bars to inner most our outer most hole? Both front and rear? Experiencing similar
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 06-19-2015, 04:27 PM   #4
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Originally Posted by khanh View Post
Hi,
Thanks.
The next modification should be springs or coil overs if they're in the budget. How many miles do you have on your Camaro? The other thing to consider is the alignment as it plays a large roll in the overall feel and responsiveness.
What are your current modifications and what tire/wheel combo?
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 06-19-2015, 04:47 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Hi,
Thanks.
Is the Body Roll side to side or is going front to rear under acceleration & braking?
Is your car lowered? I didn't see that in your signature
Old 06-20-2015, 04:48 PM   #6
khanh
I have 21000 miles on my car. I have a stock alignment.
I mean body roll from side to side. From front to rear too but not too much.
I'm not lowered. I'm afraid of the springs. Don't want the harsh ride. The only coilovers I can afford now are BC coilovers. Would they help with my problem or it is the wasted money?
performance:
suspension:
audio:
exterior:
Old 06-21-2015, 12:55 PM   #7
TwentyTen2SSRS
Drives: 2010 2SS/RS
Kind regards,
Jordan Priestley
888.308.6007
I have LT headers, can, ported throttle body, flow master American thunder cat back. pfadt 1.25" lowering springs, BMR front rear sways with FE4 conversion and Detroit speed front and rear end links.
20" ZL1 wheels on 275s up front and 315s in the rear.
Old 06-21-2015, 12:55 PM   #8
TwentyTen2SSRS
Drives: 2010 2SS/RS
Can = CAI
