![]() Drives: 2018 ZL1 A10 Join Date: Feb 2012
E85 conversion
I've seen it mentioned a few times here but I have no idea what it is or does to horsepower.
Can someone please explaine it to me? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Ethanol based fuel. 85% ethanol where most gas is 10%. Basically higher octane fuel, but you need to use ~30% more of it to work. With a big enough fuel system to handle the extra 30%, and tuning or flex fuel, you basically have race gas you can get at a pump (assuming any stations close to you). Some parts of the country have it all over, some don't have it at all. High octane lets you add timing/boost which can add power. For a NA car like yours, gains are minimal, maybe a few HP from added timing. On a turbo/blower car that can up the boost you can get 100+hp.
Nick
Corvette Z06 -1200ish rwhp |
Now I know.
Thanks! |
![]() ![]() Drives: 14 Camaro 1LE,328i, and some Hondas Join Date: May 2014
One of the key benefits of ethanol is it's cooling effect on the intake charge. It's a great fuel to run, especially if you have plenty of pumps in your area. One thing to note is being in an area that runs a winter blend. I doubt you have that issue in Alabama, but it's possible. Winter blends are usually around 75% ethanol vs. 85%.
14' Camaro 1LE - Now self-tuned
FRH ported heads, Cam Motion LL solid roller, Jesel rockers, Morel lifters, Kooks headers, Corsa exhaust, ADM intake, Stock compression/bore/stroke 551whp 504wtq |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
I'm making the switch to E-85 myself with I.D.2000s and Fore triple pumps
#6 | |
Sent from my SM-G900V using Tapatalk
#7 |
I would do ID1300s for e85, and skip the 2000s. Especially if it isn't a daily.
Nick
#8 | |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
The cool thing about the flex fuel kit is you can put straight fuel in the tank or E85 without needing a retune. Wouldn't have to worry about winter blends or not finding a E85 station. I think E85 gains NA are around 10-15 RWHP over 93 octane and 20-25RWHP over 91 octane. 10 RWHP is not a very cost effective gain if you need pump and injectors and have 93 octane available but 25RWHP is great if all you need is the flex fuel conversion and a re tune if you only have 91 octane available. Like here where I live its pretty much 91 octane only with a select few stations selling 93 octane for over $5.50 a gallon but E85 is everywhere and cheap.
#10 |
I thought the 1LE has a ZL1 pump?
#11 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
So... I'm aware of a twin turbo LS 4th gen that has gone mid 7's in the 1/4 on E85.
I know a local friend with a cam/blower manual 5th gen that has made 700rwhp on E85.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#12 |
It does. Excuse my ignorance for not looking at your avatar.
#13 |
So then the only issue would be larger injectors?
#14 |
And tuning?
