Old 06-16-2015, 07:22 PM   #1
GetYouOne
Drives: 2012 2SS/RS
Sub Frame Bushings Good Idea For Daily Drving?
I bought some Sub frame bushings from ADM and about to install my turbo. My installer said trailing arms which I bought as well is enough to help the wheel hop. He told me Sub Frame bushings make the car very stiff and are useful for track/drag. As a daily driver not so much. I dont plan on tracking my car just for DD. Thoughts?
GetYouOne is offline   Reply With Quote
Old 06-16-2015, 10:03 PM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
solid bushings?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 06-16-2015, 10:37 PM   #3
GetYouOne
Drives: 2012 2SS/RS
Yes
Originally Posted by bct10985 View Post
solid bushings?
Old 06-16-2015, 10:42 PM   #4
Synner
Drives: cars
You'll never know they're there but I would probably do the inserts for a street only car unless you have a lot of hp.
Old 06-17-2015, 03:31 AM   #5
Tim417
Drives: 2013 Camaro 2SS
I have ADM solid bushings in my car. Didnt notice any extra noise or harshness with those at all.
Tim417 is offline   Reply With Quote
Old 06-17-2015, 11:18 AM   #6
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
It will help for more than Wheel hop! It will keep the rear from moving when cornering.
mhog is offline   Reply With Quote
Old 06-17-2015, 11:35 AM   #7
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I daily drive my car, only been to the track once. Mods in my sig (including solid subframe bushings).
65k miles on the car, about 15k with all of the suspension stuff done. I would do it again in a heartbeat. The only complaint comes from my wife when she tries to drink her coffee because it's a much stiffer ride and she ends up spilling a little.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 06-17-2015, 11:41 AM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You might want to find a new installer because he is clearly not familiar with the 5th Gen. First off, the entire rear suspension of the car bolts up to the rear cradle which is then bolted to the chassis. You can upgrade all the rear arms and still have wheel hop and instability if you do not address the foundation; the rear cradle bushings. Second, you will not notice much difference in drivebility even with solid rear cradle bushings. It is really the only place in the suspension that you can get away with going full solid and not have any significant downside.
Old 06-17-2015, 11:46 AM   #9
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
There can be a slight increase in NVH, so to say "no downside" isn't completely accurate.
Old 06-17-2015, 12:41 PM   #10
Apex Motorsports
Wording adjusted.
Old 06-19-2015, 04:50 PM   #11
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
There is no draw back to going with solid sub-frame mounts. You may want to find a new installer because it sounds like he's never driven a 5th Gen with solid mounts....
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 06-23-2015, 08:47 AM   #12
ADM PERFORMANCE
Drives: Anything I want
Sounds like someone not wanting to install them if you aske me.
ADM sells these weekly and has had 0 complaints, only compliments
ADM PERFORMANCE is offline   Reply With Quote
Old 06-23-2015, 09:17 AM   #13
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
Just get it done and don't look back. I run the BMR polys and they are awesome, too.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 06-23-2015, 09:21 AM   #14
CFD
Drives: 2SS/RS L99 BLACK
I found no noticeable difference with solid mounts, if you combine them with derlin differential bushings that all changes.
CFD is offline   Reply With Quote
