Old 06-17-2015, 08:54 AM   #1
Msingh
Drives: 12 Black Camaro LS M6
CEL caused by k&n intake
i have a k&n after market cold air intake. I keep getting the CEL coming off and on here and there. But now has just styaed one. I had the local store read the code and its due to the intake sucking in too much air so its throwing the sensor off. If this ok for me to keep on driving with or should i buy that replacment sesnor that you can get at the GM store online to solve the CEL.. im assuming its messing with my fuel to air ratio...any suggestions..
Msingh is offline   Reply With Quote
Old 06-17-2015, 09:00 AM   #2
The_Blur
Moderator
The_Blur's Avatar
A new sensor won't likely help. You're better off with a tune.
warn 145:159 ban
Old 06-17-2015, 09:04 AM   #3
vinman
The BBOMG fill-in husband
vinman's Avatar
I would get a hold of K&N, they aren't supposed to throw codes, that's why I bought mine, never got a cel on my 6
UPSTATE C5 MEMBER
Old 06-17-2015, 09:07 AM   #4
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
what's the code?
FunkedOut is offline   Reply With Quote
Old 06-17-2015, 09:26 AM   #5
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Most likely an unmeasured air leak from the install. Just double check your install and make sure everything is snug down good
Tampa Tuning is offline   Reply With Quote
Old 06-17-2015, 10:33 AM   #6
Msingh
will do. thanks for the suggestions guys..
Old 06-17-2015, 01:51 PM   #7
aljeezzy
Drives: v6 6speed 2012
the other kits look more enclosed at the filter end. maybe a ram air effect is causing turbulence at the maf. other kits look dif. the kn has that 10deg elbow before the maf. other kits look straighter. i would put an extra piece of tubing inside the filter making the overall length longer or extending the filter farther. maybe put a piece of sheet metal bent around the forward side of the filter shielding it from a ram effect if its happening. testing dif stuff is kinda fun.
aljeezzy is offline   Reply With Quote
Old 06-17-2015, 05:11 PM   #8
dmginc
dmginc's Avatar
Drives: In Circles
either a leak like stated above or the MAF is dirty.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 06-17-2015, 07:08 PM   #9
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
if all else fails unhook the battery overnight
snarky is offline   Reply With Quote
Old 06-17-2015, 07:39 PM   #10
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
+1 Agree with this right here. The filter may have been over oiled and some reached the MAF . Or greasy fingers got on the MAF during install of the MAF sensor .
1Coopgt is offline   Reply With Quote
Old 06-17-2015, 07:48 PM   #11
SalMonreal
SalMonreal's Avatar
Drives: 2014 Camaro 2LS
X2, I'm thinking the battery needs to be unhooked..I did this before I installed my cold air intake(BBK)...I had a buddy who installed the k&n brand without unhooking the battery and got the CEL but later went away..
SalMonreal is offline   Reply With Quote
Old 06-17-2015, 07:51 PM   #12
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
I say get a new maf and/or reinstall everything and see if anything wasn't tightened correctly. You don't need a tune just for the k&n air intake, believe me when I installed mine about 4 years ago, I also installed a jet chip maf as well and no problems. But a tune will help make everything work together better, but if I were you I would hold off on a tune till you get some headers.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 06-17-2015, 08:27 PM   #13
Msingh
ok i opened the hood and saw something that i think is causing this CEL.. the small tube that runs from the pipe of the intake to the back of the engine seems to have come loose.. so I'm thinking thats why the CEL had not gone away..before it would come on and go off which i was fine with..but this time it didn't go away.. I'm thinking it was due to this small skinny pipe that had come off.. will drive the car more tomorrow and see if it comes off.. either way i can order the new sensor because i know this was a known issue so that why they made this aftermarket sensor for the issue of the CEL..
Old 06-17-2015, 08:38 PM   #14
YellowL99
Drives: 2014 Yellow L99
when i had a v6, first thing i did before installing my k&n intake was disconnect the battery. never had a CEL.
YellowL99 is offline   Reply With Quote
