Old 06-17-2015, 05:44 PM   #1
Z50Productions
Drives: 2015 1LT RS Camaro
Lightbulb Shifter Knob Questions
Hey all, recently purchased a 2015 1LT RS Camaro stick shift, and I'm lookin to replace the shifter knob. I've heard you need to rotate the silver ring directly under the factory knob but mine does not rotate in either direction with a substantial amount of force. Any tips/ideas before I break the da*n thing off on accident? Thanks!
Z50Productions is offline   Reply With Quote
Old 06-18-2015, 05:21 AM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
theres a screw on it to i beleave remove th 4 screws that hold the boot then pull the boot over the knob.
JCunningham is offline   Reply With Quote
Old 06-18-2015, 05:39 AM   #3
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Grab the ring and lift up and rotate it counter clockwise. Then you'll be able to push the boot down to reveal a screw on the passenger side of the knob.
If you search you'll see some pics.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 06-18-2015, 09:03 AM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Here you go. This is for the MGW install but it goes over how to remove the knob.
https://youtu.be/iR45CGOnQOo
Old 06-18-2015, 09:50 PM   #5
Z50Productions
Thanks guys. My shifter looks the exact same as the one in the video, but I can't get the silver ring to rotate like he did. I guess I'll try taking the boot off and seing if their is a screw or anything underneath
Old 06-18-2015, 11:33 PM   #6
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
Thanks for that video. I still haven't given up hope of somehow sticking an old school 'T' handle on there.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 06-20-2015, 10:17 PM   #7
Z50Productions
Finally got the d*mn thing off! The plastic had a lip on it from when it was molded or somethin that was catching. Thanks for the help all! And good luck with the T handle man. You better post pics if you figure it out!
Old 06-11-2016, 07:58 PM   #8
aevans17
Drives: 2015 1LS Black
Did anyone figure this out for the 2015?
aevans17 is offline   Reply With Quote
Old 06-11-2016, 11:22 PM   #9
CamaroDreams76
It's the same for 2015
Check out the 6min mark in the video to see how to take off the knob.
knob, shifter, shifter knob
