![]() Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
Eboost street rpm signal
Where do I get the rpm signal for eboost street controller? Thanks
I'm going to start install later today. Does anyone know? Or do I need tach adapter?
![]() ![]() ![]() Drives: it changes Join Date: Nov 2010
What do the instructions say ?
If there is no wire from the ecu to dash for the rev counter, then any 1 of the ignition coil trigger wires from ecu to each coil should work fine, but the first option would be best ( if dash receives all it's info via CAN then there will be no such wire ) |
Drives: 09 G8 GT Join Date: Jun 2011
You'll need an AutoMeter tach adapter, part#9117. They also make a plug and play LS coil harness, part#2189. Let me know if you need them, I can get them cheap.
![]() Drives: Camaro Join Date: Sep 2011
What about getting the data from pin 48 C1??
