Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 06-19-2015, 05:44 PM   #1
dpslugger12
Drives: 2013 Camaro ZL1
Michelin Pilot SS size issue
I have a completely stock ZL1 and am finally getting around to buying a new set of tires. I want the MPSS tires. So from what I've been reading, it seems the 315/35/20's will fit the rear and 295/35/20's will fit the front with no rub or anything. Is this true?
dpslugger12 is offline   Reply With Quote
Old 06-19-2015, 09:09 PM   #2
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
Correct. I have that size on my car. No rubbing.
Bigtime53 is offline   Reply With Quote
Old 06-20-2015, 09:47 AM   #3
revo1059
revo1059's Avatar
Drives: Black 2012 ZL1
I have 315s on the rear, no issues.
revo1059 is offline   Reply With Quote
Old 06-20-2015, 03:29 PM   #4
Trickskier
Native Floridian
Trickskier's Avatar
I just put 295's on the front and 315's on the rear. No rubbing and they handle great!
Old 06-20-2015, 03:35 PM   #5
HDRDTD
Absolutely true. That's what I have on mine and love them.
Old 06-29-2015, 11:37 PM   #6
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
no issues with the stabilitrak with these sizes?
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 06-30-2015, 10:13 AM   #7
ZL1Naboz
ZL1Naboz
ZL1Naboz's Avatar
Drives: '13 ZL1, ‘53 Chevy Pickup, ‘22 GMC
Are you stock height?
I am contemplating is but have BMR 1" lower all around.
Thanks
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno
559.92 RWHP 519 RWTQ
ZL1Naboz is offline   Reply With Quote
Old 06-30-2015, 10:21 AM   #8
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
I just put 295 and 315 MPSS on my SS and they fit fine--with one caveat. I have Ridetech coilovers (for now) I need a 5mm spacer on the fronts because the tire sidewall rubs on the bottom coils of the shocks. This apparently is only a problem with the Ridetechs. My Pedders actually had more clearance than the stock struts, and the 1LE stuts with BMR 1" lowering springs I'll be switching to shortly are reported not to have this problem, so I can remove the spacer once I change to the 1LE suspension.
Meh
My 5th is offline   Reply With Quote
Old 07-03-2015, 11:20 AM   #9
Trickskier
Native Floridian
Trickskier's Avatar
Thanks
Yes, I am stock height but I don't think 1" will give you a problem.
Old 07-09-2015, 09:03 AM   #10
rjs2010SS
rjs2010SS's Avatar
Drives: 2013 AGM ZL1 BELLA*
Running them now they fit perfect and even look BETTER then stock.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella*
2010 MGM Toyota Tacoma
2010 CGM SS (Traded)
1996 Black SS (Sold)
rjs2010SS is offline   Reply With Quote
Old 07-09-2015, 10:19 AM   #11
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
After my first set of PSS wore out I went to a 285 on the front just to cut down on the rocks and stuff thrown by the fronts. I do have the protectors on the front but the 295 PSS are quite wide and still throw a lot of stuff off. Reduced greatly after I went to the 285s. I realize the stagger is off a touch and maybe I get a bit more understeer but Im more of a drag racer than a road course guy.
mrvenicess is offline   Reply With Quote
Old 08-23-2015, 12:34 AM   #12
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
mrvenicess is absolutely correct. One other item to think about is the 285 do not protrude at the top of the wheelwell. I installed a 295 and it sticks out about a 1/6" on the drivers front. You will wish you installed the Michelins sooner no matter what front size you choose.
NW Sam is offline   Reply With Quote
Old 09-05-2015, 12:49 PM   #13
mbowtie71
Drives: 2013 ZL1 Vert
Did changing to a 285 on the front while keeping the 315 on the rear cause any traction control issues since the stagger is off a little bit?
mbowtie71 is offline   Reply With Quote
Old 09-10-2015, 12:44 PM   #14
Wezbad1
Wezbad1's Avatar
Drives: 2013 ZL1, 2001 Viper GTS
No, just keeps the sides of the car chip free and cleaner longer
Wezbad1 is offline   Reply With Quote
