Dashboard Lighting Quirk
If you have the key in the "on" position (the engine doesn't need to be running) to use the accessory plug (the former cigarette lighter) the dashboard and radio lights are on. If you turn the key to off and remove it without opening the drivers door the radio and ambient gauge lighting will stay on.
Don't reach in through the window and pull the key out. You need to open the driver's door to turn them off. Opening the passenger door or pressing the power button on the radio won't turn them off either. It probably isn't much of a electrical draw but I wouldn't want to risk having a dead battery. |
![]() Drives: 2011 CTS CPE & 2010 2LT/RS CGM Join Date: Jun 2009
15 minutes, check the manual.
![]() ![]() Drives: 2011 GT500 Join Date: Jun 2008
doubt that's a quirk as you can leave the halo's on the front of the car and this is the interior compliment to it.
as stated, both turn off after 15 min or so. |
![]() ![]() ![]() ![]() Drives: 2LT RS CGM Join Date: Apr 2009
doesnt this fall under the retained accessory power or what ever its called?
| DIY: Dashboard Ambient Lighting (ABL) | rharon | Camaro DIY & HOW-TO instructions & discussions | 224 | 07-23-2010 06:05 AM |
| DIY: Here it is Dashboard ambient lighting ABL | Tecca | Camaro DIY & HOW-TO instructions & discussions | 356 | 09-03-2009 10:46 AM |
| Ambient Blue/Orange Interior Lighting Around the Door, Rings, Gauges, and Dash(maybe) | pglover19 | 5th Gen Camaro SS LS LT General Discussions | 23 | 07-13-2009 09:05 PM |
| Ambient Lighting QUESTION | SuperSport2010 | 5th Gen Camaro SS LS LT General Discussions | 18 | 06-11-2009 12:37 PM |
| Ambient Lighting! | blakeequalshyphy | 5th Gen Camaro SS LS LT General Discussions | 116 | 12-29-2008 12:44 PM |
