Old 06-20-2015, 09:18 PM   #1
baranowski
baranowski's Avatar
Drives: 1968 Bronco,2001 Fatboy,2010 SS
new coilovers and wheels any tricks or tips for set up?
Hello all.
I am going from a drop spring pfadt setup to a BC coilover set up.
I am still going to use my pfadt sways and end links.
I also just changed from stock wheels and tires to forged mono block wheels with 315 35 20 tires on the rear and 275 40 20 on the front.
Since I have a little wider fenders I was thinking of using a small spacer just for the front.
That aside, anything I should know or do when I install the coilovers?
Thanks
Bill
baranowski is offline   Reply With Quote
Old 06-20-2015, 10:26 PM   #2
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 06-22-2015, 06:22 AM   #3
baranowski
baranowski's Avatar
All weekend long and nothing?
Old 06-23-2015, 12:23 PM   #4
baranowski
baranowski's Avatar
Ok. If I buy these coilovers used... what is a good starting place to set them for stiffness and height?
Old 06-23-2015, 12:29 PM   #5
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
Set everything in the middle and then just adjust softer/stiffer on the front or rear end of the car to get to where you want it to be. Adjustments on the rear of these cars with the BC coilovers isn't the easiest thing in the planet, you'll need extenders and to drill a hole in the trunk to allow access, but it's a great inexpensive set that we sell a ton of here. For ride height, that's more of a preference if anything, so get a good feel for where you'd like it to sit!
ModBargains.com is offline   Reply With Quote
Old 06-23-2015, 02:29 PM   #6
baranowski
baranowski's Avatar
I currently have drop springs on the car. So I would like to start at about 1.25 inch drop. I would like to set the coilovers Close before they go on the car. Is there a measurement that would be a good starting point?
