06-21-2015, 07:22 AM | #1 |
Horsepower Therapy
Drives: 2014 2SS, RS, 1LE, Heartbeat Blower Join Date: Oct 2013
J Audio XD700/5 settings questions
All,
I am looking for some advice on settings for a JL XD700/5 amp, with all aftermarket speakers and sub. I initialing only installed a JL 10in Sub in a stealth box, but have since upgraded the factory speaker to all JP audio. I admit it, I am not a "sound" guy so when i look at all the setting on the amp it's like looking at hieroglyphics or a hog looking at a wrist watch. So, the big questions - How to set the CH 1/2 HP filter switch, and filter freq on dial. Same for CH 3/4, what would you do for Filter Mode, etc? For the sub, 12db or 24db? Advice would be appreciated.
Like us on Facebook and Instagram - Horsepower Therapy...... www.horsepowertherapy.org |
06-21-2015, 08:39 AM | #2 |
Ok, since you don't mention what kinds (co-ax, comps) you have int the front doors and in the back, I'm going to assume you bought JL components with a passive x-over for the front and 6X9 2 ways for the rear. Also, I'm assuming you are using the stock radio and some sort of lineout converter or the ******** X3 to get signal to the amps. If not, disregard the following
Channel 1-2 (fronts) you want to set the filter to high-pass at 80Hz Channel 3-4 (rears) you want to set it to either either off or also 80Hz. (I would personally disable the rear speakers totally unless there are always passengers back there with you) For the Sub channel, set the filter to 80Hz. The slope (12 or 24) you will need to play with to see which allows the sub to blend better with the fronts. You will also need to set the gains (input sensitivity) properly on the amp. Here is a link to JL Audio tutorial on doing that: http://www.jlaudio.ca/header/Support...Setting/624628 If you post more detailed info about your setup we can provide better answers too
2021 2SS A10 - Summit White - NPP - MRC - Adrenaline Red Interior Pkg - Black Appearance Pkg - Ground Effect Pkg - Suede Steering Wheel and shifter - Red Calipers - Carbon Flash Wheels w black lug nuts - DD Tinted Side Markers - Hero Tinted Rear Reflectors - Redline Fender Badges - 20% Tint
Audio System Build Log ----------------------------------------------------------- 2014 Z/28 Summit White - sold 2020 2010 2SS/RS Summit White - sold 2014 |
06-21-2015, 09:36 AM | #3 | |
Horsepower Therapy
06-21-2015, 12:21 PM | #4 |
If the 6X9 are two ways, you can do high-pass, but it will diffuse your stage. If you put a BP filter then I'm not sure what the value is for the low pass side... In general, to get good rear fill is almost impossible without a DSP and even then it's hard.
06-21-2015, 12:27 PM | #5 |
I just read through your build log. Awesome car man!!!
06-21-2015, 02:56 PM | #6 |
Horsepower Therapy
06-22-2015, 11:37 AM | #7 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
I just setup my own JL 700/5 amp with the stock BA speakers and a 12" sub. I just sat in the car and tried everything to get the sound I wanted. I know that's not telling you exactly what to do but it's what I did to get mine to sound like I wanted.
I'm not trying to sound like a douche but read the manual, it actually has some good info in it. I'm in a hurry now but I'll check back later to see if I can give you some better info.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
