nathank2563
Drives: 2015 Camaro SS 2SS w/RS Join Date: Jun 2015
front swaybar? help please
hey guys i'm kinda inexperienced with cars, but my dad is and he is willing to help me install a front swaybar to try and limit the bodyroll and understeer in my 2015 camaro ss.
any suggestions for a reliable and durable front swaybar? will any model year swaybar fit the 2015? (and should i keep the stock end links? one of my friends told me that if i'm not going to the track, i should just get a new swaybar and keep the stock end links) thanks in advance guys! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Get a set from BMR, both front and rear. The back end of these Camaro's need more help than the front- IMHO.
![]() You'll find what you need here and use their instructions to install- http://www.bmrsuspension.com/?page=p...d=77&catid=225 And your buddy's right, the stock end links will work just fine. |
#3 | |
nathank2563
OMINOUS
Drives: '10 Camaro 2SS/RS M6 Join Date: Dec 2012
Pedder's also is another good choice for sway bars! I got them on my bagged Camaro!
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
If you only want to do one sway bar, do the rear, not the front. Adding a stiffer front bar and keeping the stock rear bar will only make your understeer worse.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Black 2011 2SS/RS Join Date: May 2011
http://www.jpssonline.com/jpss-black-magic-sway-bars/ |
#7 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
ZL1 sway bars and end links are a good upgrade and they're OEM pieces which is nice.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#9 |
Slow
What's a set of zl1 end links to for?will they work with my stock sway bar 14ss/rs auto?
