Old 06-22-2015, 12:02 PM   #1
Rachelneb
Drives: 2013 SS Black Camaro
Problem with USB on MyLinks
I just picked up a 2013 camaro a few days ago. I have been having multiple problems with the USB. When I plug in a USB with all my music on it, it doesn't always recognized it. After it finds it, it plays music fine. But when I shut my car off and turn it back on, it'll either not recognize it or it'll start back at the first song I have on thr USB. Really gets annoying fast and it's pointless to use if not on long trips. Anyone else have this problem or know how to fix??
Rachelneb is offline   Reply With Quote
Old 06-22-2015, 12:40 PM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
First, it's "MyLink". I doubt you have more than one.
Not all USB drives work well. Try using a different brand/model.
As for playback, there are options in the setup to control playback. Default I believe is numerical order. Mine is set to random or shuffle.
JimE is offline   Reply With Quote
Old 06-22-2015, 01:58 PM   #3
JSLSlim
JSLSlim's Avatar
Drives: 2013 2LT/RS A6
I, too, have run into this problem and for me it was related to how many files I had on the USB stick. I am currently using a Sandisk Ultra Fit USB 3.0 64GB flash drive and it works well. I was formerly using a Patriot Axel USB 2.0 64GB and I had a lot of performance problems using that drive. I also found that if you exceed the 10,000 file limit on your drive you will have indexing problems and the skipping back to the same file every time you startup the USB. Lastly, when I transferred files in Windows using Explorer, i would inadvertently copy all of the accessory files (e.g. THUMBS.DB, folder art files etc.) and these are counted in that 10,000 file limite. Eliminating these extraneous files from my USB drive freed up a lot of files...
Dealership selected and Order Placed with Dealer (7/1/2012)
1100 Order Placed at Dealership (7/2/2012)
1102 Order Entered via Web (7/2/2012)
2030 Order Edited by Chevrolet (7/12/2012)
3300 Order Selected and Scheduled for Production by Assembly Plant (8/9/2012 - TPW: 8/20/2012)
3800 Vehicle Produced (8/25/2012)
4B00 Bayed (9/4/2012)
5000 Vehicle Delivered to Dealership (9/18/2012)
6000 Vehicle Delivered to Customer (9/19/2012)
JSLSlim is offline   Reply With Quote
Old 06-22-2015, 02:04 PM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Mylink is FAAAAAAAAAAAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRR from perfect.
FSP tuned: 377/389
Old 06-22-2015, 03:28 PM   #5
seven
seven's Avatar
Drives: 2015 Camaro RS 2LT AGM
That's great to know. My USB worked fine for few months then all files gone but one song. I re copied and worked for a few days then same thing. I now have a lot less songs on it and no problems. I will check out the info you provided. Thanks
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions)
seven is offline   Reply With Quote
Old 06-22-2015, 03:28 PM   #6
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
I have had mine lock up a time or two, but other than that, and it could have been that I bumped it while in the console compartment, I have not had any problems in our 2014.
I keep it on shuffle also.
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 06-22-2015, 09:10 PM   #7
The Patriot
Drives: 2014 2SS/RS VERT
I have a problem with mine getting stuck on "fast forward" sometimes when I start the car, I have to change to another source and then back to USB to get rid of the chipmunks.
2014 2SS/RS Vert.
"Today I didn't even have to use my AK, I got ta' say it was a good day"
The Patriot is offline   Reply With Quote
Old 06-22-2015, 09:27 PM   #8
Dznyfn
Dznyfn's Avatar
Drives: 13 1SS Vert, 05 Tahoe Z71, 67 RS/SS
Exact same problem with my 2011 and my 2013. 2011 dealership bought back the car and replaced with the 2013. Every time i run into a store, doesn't matter the time, it doesn't recognize the usb or iPod. I have to unplug it then plug it back in to work. But it does start back where it left off in the song which is weird.
Dznyfn is offline   Reply With Quote
Old 06-23-2015, 02:04 PM   #9
JimE
JimE's Avatar
There is a 10,000 file limit as noted in the sticky in the audio section and the Infotainment User Manual.
> http://www.camaro5.com/forums/showth...08#post8497208
Old 06-23-2015, 10:26 PM   #10
Dznyfn
Dznyfn's Avatar
Yes, I know. I only have about 500 or so.
