Old 06-22-2015, 03:26 PM   #1
chalhoee
chalhoee's Avatar
Drives: 2010 M6 2SS/RS
XA coilovers not lowering??
Hello,
Has anyone run Pedders XA coil overs on their car? I bought some for mine but the rear sits higher than stock with the adjustment at the lowest setting. I bought these used and tried contacting pedders with no luck. Don't know what could possibly be happening here I did all the pre-load right and everything. Just wondering if anyone else has experienced this issue.
Thanks
SW 2010 2SS/RS
Currently at 608whp/701tq
-229/236 CAM-VR-BBK LT's-Vmaxx TB-O/F Xpipe-LM2's
-LS3 ported heads/Mani
-Wet Nozzle 150 shot
-Tuned by Solid Tech Performance (ABQ, NM)
chalhoee is offline   Reply With Quote
Old 06-22-2015, 04:56 PM   #2
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/ ctsv3
You need to take loose the bottom locking ring and thread the tube down into the mount, you would turn the top locking ring clockwise to lower the vehicle. Make sure the car is jacked up so no weight is on the coil over you are adjusting
2012InfernoSS is offline   Reply With Quote
Old 06-22-2015, 07:49 PM   #3
chalhoee
chalhoee's Avatar
I did that but the tube hits the inside bottom of the holder and it doesn't let it go down any further. This being the lowest setting, right before it hits the bottom of the holder, i put the car down and the ride height is higher than stock. I understand you drive it and it settles but its not gonna go down 4" lol Didn't have a problem with the front ones its just these back ones that are giving me trouble. I appreciate the help though, thanks.
SW 2010 2SS/RS
Old 06-28-2015, 05:54 PM   #4
2012InfernoSS
Sorry im not sure then, only thing I can think of is the rears have the wrong tube on them. I believe the front tubes are longer then the rears.. Did you have them all apart and maybe mixed the tubes up
Old 06-28-2015, 08:51 PM   #5
Mike_G
Drives: 2010 2SS/RS
can you post a pic of the coilover and how you have it set up? How much tension is on the spring perch holding the spring in place?
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 06-28-2015, 08:57 PM   #6
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Make sure your rear shock mounts aren't up-side down
AG1LE is offline   Reply With Quote
Old 08-19-2015, 04:39 PM   #7
chalhoee
chalhoee's Avatar
Figured out my issue guys..... turns out I have a kit for a G8 not a 5th gen. monotubes are different lengths therefore limiting the adjustment margin. I appreciate all the input guys!
SW 2010 2SS/RS
