Go Gators!
Drives: Camaro Jeep Abarth 944 325i Join Date: Jan 2013
Hello all,
I almost purchased some BMR front and rear sways a few months ago but then lost the time to be able to install them. Now I finally have the time but I wanted to do some last minute research and get a good feeler to make sure I make the best purchase. I don't want to drop the car and I only want to start off with front and rear sways. I plan to add a tower brace and end links as well. Input on these other pieces are welcomed as well! What will give me the best handling improvement? -1LE Sways (probably will find em used) -BMR Sways -Hotchkis Sways -Justice Pete Sways -LSR Sways I need your input and real world experience. Plan to purchase soon. ![]()
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts Engine Mods: All bolt ons (haha) Brake Mods: Brembo SS caliper swap front and rear Last edited by Airmaster; 06-23-2015 at 10:53 PM. Reason: add LSR |
Go Gators!
I'm actually gonna add LSR front and rear sways too
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts Engine Mods: All bolt ons (haha) Brake Mods: Brembo SS caliper swap front and rear |
Banned
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
That is easy to answer, who of those listed has dozens and dozens of engineers that are hired solely to make the camaro the best that it can be and then spent 10's of millions of $$$ proving it?
#4 | |
![]() ![]() ![]() ![]() Drives: Supercharged LLT Join Date: Aug 2012
Haha jk |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: cars Join Date: May 2011
#6 |
Cone Killer
Drives: 2012 SS Join Date: Dec 2013
Whatever you do, I'd look at getting at least a 5mm size difference between them, so that the rear is at least 5mm larger than the front. If you go with the 1LE bars, I'd look at just getting the rear bar. most of the aftermarket setups seem to run around a 5mm split.
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out! |
#7 | |
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
The one downside I have now though is that the inside rear tire will spin more on exiting corners on some autocross courses. The is obviously because of the sway bar lifting the inside tire. What I don't know is whether going with aftermarket front and rear bars would resolve this, or if I would still wind up with enough bias between front/rear that I wouldn't matter. If aftermarket front/rear bars wouldn't fix that then my only other solution is coilovers and go with softer sways. On track though I didn't have any issues with inside tire spin, it's so far only been on some autocross courses where there is a longish sweeping exit with a straight following.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
Well you know I'm going to say BMR. Plus your close, you can drive to Tampa, pick them up and be done!
#9 |
Drives: Camaro Justice Join Date: Jun 2007
Back in 2009 we ran the biggest rear bar the OEM sway bar strap bolts could hold, 32mm. As soon as the new style out board arms were available we ran a 32mm rear bar, the biggest the OE hardware can handle. Fast forward to 2015 and you see that imitation is the sincerest form of flattery.
#10 | |
Go Gators!
#11 | |
Go Gators!
Does anyone have specifics? Do brakes have to be changed?
#12 |
To my knowledge, my out board mount JPSS rear sway bar is the only one that clears the banjo bolts on your V6 calipers.
#13 |
Go Gators!
How does everyone else feel about the solid vs hollow sways? Any one have trouble with hollow sways?
#14 |
![]() Drives: 2010 ABM w/white hockey stripes Join Date: Aug 2012
The early model year 5th Gens delivered with hollow bars. When they changed to the out board mount rear bar they also changed from hollow to solid bars.
