![]() Drives: 2015 ZL1 Coupe A6 & 2002 ZO6 Join Date: Apr 2014
Fuel Pump Voltage Booster
Which one? MSD, JMS or Kenne Bell?? Your thoughts....pros, cons??
Thanks
2015 ZL1 A6 Coupe Crystal Red
ATI Balancer w/9.55 (22.5%) lower pulley, FIC1000 Injectors, Stainless Works 2" headers, Stainless Works Retro Cat-Back, V-Max Ported TB, Roto-Fab w/Big Gulp, Elite 2nd Gen Catch Can, Jannetty Tuned. 581 rwhp |
I'm leaning towards the JMS I think. I've been talking to Ted Jannetty the last couple days and he pretty much got me talked into it. It seems the JMS is superior to the MSD or KB.
![]() Drives: 2012 Camaro ZL1 Join Date: Jun 2014
I have the JMS as well and it is great. Got a defective unit and they replaced right away. Instructions aren't very good though.
11.633 @ 118.85 Stock M6 Drag Radials
What do you like about it? What advantages does it have over MSD or KB?
Too much is never enough!
I've got a 40 amp ECS BAP for sale, if your willing to wait till mid july, I'll have an MSD 2351 programmable BAP you can get your hands on.
