![]() Drives: 1996 Z28/SS, 2013 ZL1 Join Date: Jan 2015
Exhaust Leak
I put a set of KOOKS on and re-used the factory clamps to the factory cat back. I tightened the mid-pipes once since installing them, but still sounds like a small leak coming from the factory clamps. Has anyone had problems with the factory clamps leaking?
13 Camaro ZL1 IOM #3976
96 SS Camaro #1664, 04 2500 Dirtymax ZL1 Current Mods: KOOKS 2" w/orp, BTR Stage 3 Cam, LPE 2.55, LPE 9.1, ATI Damper, LPE Isolator Coupling, LPE CAI, Ported TB/Snout/Blower, JMS BAP, ID-850, 160 T, Ron Davis HX, D3 Reservoir, Elite Eng CC Gen2... |
![]() Drives: 2013 Black ZL1 Join Date: Jul 2014
Mine leak a bit until the system warms up and expands. Once heated the leak seals
Mine leaks (ticks) when its warm and I never hear it at idle, only when I'm cruising with the windows down and im in second or third above 2300 rpm. I re-torqued the headers and I installed new GM gaskets when I put the headers on and the tick sounds like its coming from around where the mid-pipes are so that's why I assume its at the factory clamp.
Hmm have you retightened the clamps after a few heat cycles?
Yep, I'm going to look at it tonight maybe I can fix it. Its driving me
#6 |
Go fast, please.
Is this common when installing headers?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 1SS 1LE Vivid Orange Join Date: Mar 2011
Thank you for this thread! I just installed headers a couple of weeks ago. Today I was out driving and the ticking was really noticeable at idle when warmed up. It has to be an exhaust leak. I re-used the factory clamps behind the Cats as well. Are there aftermarket clamps out there that are as good or better?
I'm going to get under there tomorrow and re-torque everything.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
#8 |
My engine has a "tick" at idle that is not related to the headers. You can hear it from the wheel wells and under the car decently. With the hood pope you can't hear it. Thought it was a lifter but honestly doesn't sound metal on metal nor is it that loud but it increases with rpm. it drives me up a wall. Honestly hate it, it's prominent on the driver side front wheel well towards the back of my motor. I talked to a few other people and said theirs make the same noise.... car has 4500 miles on it
#9 |
ZL1Naboz
Drives: '13 ZL1, ‘53 Chevy Pickup, ‘22 GMC Join Date: Mar 2013
Injectors?
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno 559.92 RWHP 519 RWTQ |
#10 |
I can hear the injector clicks when I pop the hood something different.
#11 | |
I think I found mine last night, the driver side clamp was crooked a little and I had to pull my cat-back over when I tightened the clamp. It sits better now, but taking it to Street Machine Nationals this weekend hope its fixed!
#12 |
I'll be re-torquing everything today and I'll report back. I'm sure that's what it is.
Yes, I can only hear it ticking at idle. The exhaust is too loud to hear it while I'm driving.
Dan |
#13 |
![]() ![]() ![]() Drives: ZL1 1LE A10 Join Date: Mar 2015
I had my headers done recently too and I definitely hear an exhaust leak sound. Its annoying but it gets a bit less noticeable when things warm up.
I had the same problem with my '13 GT500. It ended up completely going away after 3-6 months. I wonder if the soot creates a natural seal over time. I hope it goes away in my Z. :/
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
#14 |
KaBoom1701
Anybody know what the torque specs on the header bolts are?
Mods:
