![]() Drives: 2013 Summit White ZL1 Join Date: Jun 2014
Catless question.
So I plan on installing Jba catless mid pipes. Now I know that I will get a CEL. Does the car have to be tuned on a dyno, or can I use a hand held tuner and just turn the rear 02 sensors off? Other mods are ported vmaxx tb and roto-fab intake.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
someone like Jannetty could easily tune for no cats remotely using a hand held tuner. Tuning on the dyno is most ideal as the fueling can be adjusted for the lack of cats, but not entirely necessary.
#3 | |
![]() Drives: 1996 Z28/SS, 2013 ZL1 Join Date: Jan 2015
If you know someone that has HP Tuners or something comparable, you could just turn the O2's off. But you would gain more with having someone tune it.
13 Camaro ZL1 IOM #3976
96 SS Camaro #1664, 04 2500 Dirtymax ZL1 Current Mods: KOOKS 2" w/orp, BTR Stage 3 Cam, LPE 2.55, LPE 9.1, ATI Damper, LPE Isolator Coupling, LPE CAI, Ported TB/Snout/Blower, JMS BAP, ID-850, 160 T, Ron Davis HX, D3 Reservoir, Elite Eng CC Gen2... |
Emerald Coast Camaro's
Drives: 2014 ZL1 Join Date: Dec 2011
Going catless is obnoxiously loud and not the good kind. I haven't heard a setup without cats that sounds good. A lot of people will run a resonated x pipe but I didn't have any luck with the catless setup
![]() Drives: 2012 Camaro ZL1 Join Date: Jun 2014
Your opinion. I have no cats and long tubes and to me it sounds awesome. Plenty of others will agree too.
11.633 @ 118.85 Stock M6 Drag Radials
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Yah no cats and long tubes sound great to me. Maybe if you don't have mufflers then it wouldn't sound as good.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
#7 |
Yeah I agree that full dyno would be the best option as far as power and setting fuel ratios. I have a wideband air fuel gauge so that will help in the tuning process. I also forgot to mention that i have a corsa catback going on the car with the midpipes.
#8 | ||
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Mar 2013
A dyno tune won't necessarily get you tons of additional power, (generally within 5hp,) but it will definitely get you a smoother power curve, and better drivability. Not to undermine Janetty, he's been doing this for a while, but a good tuner on a dyno will always be better than the same tuner via email.
As for LTs and no cats, I think it's great with the stock catback. No drone, shuts up really quiet on the freeway, and makes plenty of noise when you're high up in the revs.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
#9 |
Madman
no cats
my 14 zl1 runs no cats,long tubes, loud, yes..controllable..yes
#10 |
I am looking at this exact situation right now for my car. I'm thinking of going catless more out of concern that poor quality cats may cause enfine damage then anything else. I drive my ZL a lot, about 25K miles per year, and I don't want any hassles. Thinking Ilugot catless and if too loud I can always add them back in later.
Thoughts?nfeedback and sound clips would be appreciated.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
#11 |
![]() Drives: 2010 2SS/RS L99 SLP Cosmetics Join Date: Sep 2014
^^ This^^
13.244 @ 104.91 100% stock (#17).
Now - Mike Norris catch can. 245/50/19 Firestone Wingfoot A/S on LT2 black powder coated rims (square). 1 7/8" Speed-Engineering LTH, off road pipes, tune. Now 12.93 @ 109.13. |
#12 |
So question is. Do I do my catless mids and corsa and do it with a handheld tuner and just shut off rear O2's? Or throw it on a dyno?
