Old 06-27-2015, 04:36 PM   #1
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Just cut filter open on new motor.
Used Joe Gibbs breaking oil and after tuning the car changed the oil and cut filter here's what I found. Normal for a new engine? Or is it killing the bearings?
Nitroman28 is offline   Reply With Quote
Old 06-27-2015, 04:44 PM   #2
Scott@Bjorn3D
I would say normal for new engine. Keep on eye on it with next change and should be less.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-27-2015, 09:17 PM   #3
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Mike if it's copper color bearings are getting ate up. Do u know what bearing clearances it was built with on rods and mains?
Rhino79 is offline   Reply With Quote
Old 06-27-2015, 09:18 PM   #4
Nitroman28
Nitroman28's Avatar
No idea. Texas speed built it.
Old 06-27-2015, 09:19 PM   #5
Nitroman28
Nitroman28's Avatar
Oil pressure is staying the same as when it first fired up.
Old 06-27-2015, 09:23 PM   #6
motorhead
Hard to tell color from pics, but I just found rod bearing out of my friends chevy truck that had bits like that in the oil. His also had terrible rod knock though. That was why we drained the oil. That amount of metal looks excessive. I would be consulting your engine builder for sure.
Old 06-27-2015, 11:53 PM   #7
762ch
Drives: 2011 2SS
Ask TSP about it, they will have some good advice. It might also be a good idea to send your oil to Blackstone for analysis from now on.
762ch is offline   Reply With Quote
Old 06-28-2015, 12:04 AM   #8
Nitroman28
Nitroman28's Avatar
Yea. I'm going to call them Monday.
Old 06-28-2015, 12:47 AM   #9
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Could also be shavings from when the block was machined?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-28-2015, 12:49 AM   #10
Nitroman28
Nitroman28's Avatar
It's all gold flakes.
Old 06-28-2015, 02:00 AM   #11
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Looks bad! Far more metal than would be expected for normal break-in!
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 06-28-2015, 09:24 AM   #12
christianchevell
old school chevy rodder
christianchevell's Avatar
I would also have to say that's normal for a new engine.... And now 500 miles later the next round should show a lot less shavings, new engines etc are not hot tanked after milling on a lot of parts good enough to remove all shavings or blown clean enough. Also I would get a magnetic oil pan plug available through g.m., bought one long ago at a dealership.
Old 06-28-2015, 09:41 AM   #13
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
looks fine, its in the filter so I wouldn't worry about it.
revived is offline   Reply With Quote
Old 06-28-2015, 09:45 AM   #14
motorhead
The oil can make it look gold. It's probably silver in this case. Does a magnet stick to it.?
