Old 06-29-2015, 09:55 AM   #1
TheDestructo
Drives: Camaro
Build Plan: 500 rwhp 2014 1LE, thoughts?
I'm looking to get back into the f-body game (previously owned a '67 RS/SS and a '97 Z28) with a '14 1LE in the next 12 months or so.
I am a planner by nature, so i'm sorting out a build plan to have in place when I do bring the new car home.
I'm seeing a few 500+ rwhp n/a figures on the threads (which is where I'd like to end up).
I'm definitely of the "have a more tuned and built naturally aspirated car" with a decent drive mod than forced-induction and/or just trying to brag how much power I have, blah blah blah.
The 1LE appeals to me in those senses, but I'm thinking the only things I'd look to do in the power department would be at the worst: Heads, cam, supporting tune, intake, ported throttle body and full exhaust. Am i missing anything here for the goal of 500rwhp?
Suspension and tires are a whole other animal
Thanks for reading, and keep up the great 1LE posts, I'm loving what I'm seeing!
TheDestructo is offline   Reply With Quote
Old 06-29-2015, 10:00 AM   #2
thunderkyss
Drives: 2015 Red Hot SS/RS M6
Everybody's got to have goals.
You seem to be on the right track. Good luck.
thunderkyss is offline   Reply With Quote
Old 06-29-2015, 11:15 AM   #3
TheDestructo
Drives: Camaro
Roger that. Thanks!
Old 06-29-2015, 11:59 AM   #4
The Hunter
The Hunter's Avatar
Drives: 2015 Summit White 2SS/RS 1LE
I am trying to do 500 rwhp as well. Here is a thread from not to long ago that might help if you haven't seen it. http://www.camaro5.com/forums/showth...&highlight=500
The Hunter is offline   Reply With Quote
Old 06-29-2015, 12:24 PM   #5
TheDestructo
Drives: Camaro
Saw that one. Thanks for posting though, good to get more examples and information.
How's your build coming along? Where are you at in the stages and what's left?
Old 06-29-2015, 01:11 PM   #6
The Hunter
The Hunter's Avatar
I have the list of everything I'm getting as far as parts goes but just need to pull the trigger and find a local shop that will do the work and tune.
Old 06-29-2015, 01:21 PM   #7
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
500whp should be easily achieved with a good h/c/i set up.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 06-29-2015, 01:26 PM   #8
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
I would also do the Comp Cams trunnion bearing upgrade.
Bhobbs is offline   Reply With Quote
Old 06-29-2015, 02:17 PM   #9
TheDestructo
Drives: Camaro
Care to elaborate on why? Just genuinely curious, thanks!
Old 06-29-2015, 03:24 PM   #10
The Hunter
The Hunter's Avatar
Here is a good explanation I found, and if you are thinking about getting heads then you might as well replace them while they are off along with the valve springs and pushrods
http://www.autoserviceprofessional.c...ak-link?Page=2
Old 06-29-2015, 09:36 PM   #11
Bodywerks
Drives: 2015 2SS/RS/1LE
I'm also in the same boat, but I personally plan to try to get there without an aftermarket intake. The intake seems to kill the torque, which in my opinion is just as important.
The 1le in the above linked thread, sure, it made 525ish rwhp, but a mere 440ish torque. I am currently at bolt ons and tuned and running 423 rwtq.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 06-29-2015, 10:41 PM   #12
TheDestructo
Drives: Camaro
Good to know! I'm picking up quite a bit here, so keep the good information coming, thanks!
Old 06-29-2015, 10:43 PM   #13
TheDestructo
Drives: Camaro
Interesting information. I'd be curious to know if there are any aftermarket that don't impede the torque numbers, that's important for sure.
Old 06-29-2015, 10:52 PM   #14
JusticePete
Drives: Camaro Justice
500 RWHP works, but once you upgrade suspension and start holding steady state high G turns a dry sump should be on the mod list.
