Old 06-29-2015, 10:12 AM   #1
Jugdishian
Drives: 2015 2SS 1LE
1LE Coilovers
Ok, what would you guys recommend as far as specific coilover for my 1le. I see a lot of people with peddlers but they are out of business from what i understand. Please be specific with brand and model please as I don't know a lot about these kind of things. Money is not a factor....to a point.
Jugdishian is offline   Reply With Quote
Old 06-29-2015, 10:40 AM   #2
lenamie
Drives: 2010 ABM w/white hockey stripes
Before yo are inundated with buy this brand coilover, can you tell me more about how you use your 1LE, what the plans are for upgrades and the ultimate goal for you build?
lenamie is offline   Reply With Quote
Old 06-29-2015, 01:54 PM   #3
Jugdishian
Ok, I want to lower my car and improve handling. It will see track use only about once per year but I have some decent roads that are entertaining. Adding some simple bolt ons...CAI, Headers, etc. Nothing to drastic.
Old 06-29-2015, 10:19 PM   #4
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
The 1LE will do almost everything you ask of a street driven car. Unless looking for a lowered stance the 1LE handles very well as designed.
Zombie killer is offline   Reply With Quote
Old 06-29-2015, 10:34 PM   #5
JusticePete
Drives: Camaro Justice
The damping in the 1LE struts is really very good. The low priced coilovers will barley be equivalent. Cosmetics / lowering aside, you can get great handling gains from a few other 1LE upgrades.
Swap out your front 1LE sway bar for the smaller SS/ZL1 25mm bar. The cost online is about $110. The big rear small front will make your already great handling 1LE even more neutral. You can replace just the rear bar with a JPSS 32mm bar and be even more neutral with a bias toward oversteer -- even better
Add a degree o caster to bring your steering back on center more quickly and to track better at higher speeds with JPSS Caster Locks.
Improve your on center steering by reducing the dynamic caster changes allowed by the rubber insert from the factory in the radius arms with JPSS Billet Bushings made of aluminum or Delrin. They are like magic.
If you really want to lower, we can drop you with a Z/28 light kit. Ship me you complete 1LE strut assemblies and I'll fit Z/28 coils to them. The rates are next to perfect. The spring rates are on the high side for the 1LE struts, but we have some in the field and one in particular tearing up road courses. The owners love them
I do know of one Z/28 set of DSSV struts and springs we can get at a bargain price, comparable to mid level coilovers.
Let me know what your thoughts are.
Old 06-30-2015, 03:36 AM   #6
Tim417
Drives: 2013 Camaro 2SS
How much will the Z28 Light kit lower the car from stock?
Tim417 is offline   Reply With Quote
Old 06-30-2015, 09:31 AM   #7
JusticePete
Varies about 5mm Camaro to Camarop depending on your current ride height, but 10mm front and 15mm rear. Not a lot, but enough to notice the difference. The big gain is in spring rate and how the car drives.
Old 07-02-2015, 02:06 PM   #8
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
I am looking for coilovers too for my 1le and for money cant seem to find anything better than KW v3s or club sports. Would love ridetechs but the cost is 1500 bucks more and aluminum gives me nightmares on coilovers. The bilsteins seem very cheap too for a quality damper.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 07-02-2015, 03:38 PM   #9
JusticePete
Can't you get a GM discount on the DSSV setup?
Old 07-02-2015, 04:16 PM   #10
Mgizzle
Mgizzle's Avatar
I am considering the z/28 kit but worried about not enough lowering after all the mass removal. I cant even get -1.4 front and -1 camber on rear anymore, z/28 dampers wouldnt help with that much, coils most likely would.
Old 07-02-2015, 04:18 PM   #11
JusticePete
what does your Camaro weigh now?
Old 07-05-2015, 01:05 PM   #12
Mgizzle
Mgizzle's Avatar
About 3700lbs.
