Old 06-29-2015, 02:25 PM   #1
M0dnar
Drives: 2015 Corvette 3LT with Z51
Increasing Ride Height
So I have the opposite problem as everyone else. I need to raise the front end of my car by at least an inch if not two. I was originally going to get the KW Clubsport, but the highest setting for the front is still a 1 inch drop. Does anyone know of any coilovers or springs that would raise the ride height?
M0dnar is offline   Reply With Quote
Old 06-29-2015, 02:35 PM   #2
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
Don't know of any shocks/springs/coilovers that would accomplish what you need. But going to a 22" wheel would raise your entire car off the ground by 1 additional inch without increasing the fender-gap. A 24" wheel would get you two inches over stock (assuming you are running OEM 20" wheels).
Billy10mm is offline   Reply With Quote
Old 06-29-2015, 02:36 PM   #3
M0dnar
Lol I'm running 18s with a 35 section height.
Old 06-29-2015, 03:08 PM   #4
Billy10mm
Billy10mm's Avatar
Then a set of 20" OEM SS wheels would get you an inch right off the bat, and a set of 22" wheels would get you your required two inches.
Old 06-29-2015, 03:33 PM   #5
M0dnar
Problem is I just bought and mounted new tires and wheels and then I started having ride height issues. Would prefer not to have to replace wheels and tires.
Old 06-29-2015, 08:19 PM   #6
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Not so sure about that . I think the OD of the 18" rim with tires on them equal the OD of the 20" rim with tire .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 06-29-2015, 08:24 PM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Why do you want to lift the front end anyway??
Old 06-29-2015, 08:25 PM   #8
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
Get some air lift suspension, problem solved.
Rico is offline   Reply With Quote
Old 06-29-2015, 11:05 PM   #9
JusticePete
Drives: Camaro Justice
Bagging is the only option you have to raise your Camaro.
Old 06-29-2015, 11:18 PM   #10
Mean Green Z28
Drives: 2010 2SS
http://www.amazon.com/gp/aw/d/B00029...SBL&ref=plSrch
Or get the rubber donut style spacers but that requires taking them apart
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 06-30-2015, 09:32 AM   #11
JusticePete
SMH
Old 06-30-2015, 09:39 AM   #12
Billy10mm
Billy10mm's Avatar
He mentioned a 35 AR tire, I do not believe the stock 18s are a 35. He also mentioned just spending money on wheels and tires, so I don't believe he's running a stock setup.
Old 06-30-2015, 12:52 PM   #13
M0dnar
Might try the spacers in the short term, but it looks like long term solution is air ride. Yay for spending money!!!
And I need to raise the front end because with the smaller, lighter tire/wheel setup my twin turbo skid plate is barely an inch off the ground. I bottomed out at 80 MPH on the freeway this weekend and the local drop has a similar crest/hump where I'll bottom out at much higher.
