Old 06-29-2015, 08:18 PM   #1
rcandiloro
rcandiloro's Avatar
Drives: 2018 ZLE
Cold Air Induction CAI Install Question?
So I just got my CAI and was all ready for the easy 20-30 minute install and I'm stuck on step #1, disconnect negative battery cable. I know a lot of folks skip this, but it's connected to the stock intake and I cannot for the life of me figure out how to get that sucker off. Any advice, specifically getting that thing off, would be helpful. Very frustrated. Thanks so much for any recommendations.
rcandiloro is offline   Reply With Quote
Old 06-29-2015, 08:27 PM   #2
rcandiloro
rcandiloro's Avatar
Drives: 2018 ZLE
Never mind, I'm an idiot, figured it out.....
Old 06-29-2015, 09:16 PM   #3
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado
The battery is in the trunk.
ZL W0N is offline   Reply With Quote
Old 06-29-2015, 09:26 PM   #4
Balasarius
Balasarius's Avatar
Drives: 2015 ZL1
HAHA 20-30 minutes. Yeah, right!
After 2 hours of blood, sweat, and tears I finally got mine installed. Barely.
I now get to enjoy the remainder of my ZL1 ownership worrying about the air filter slipping off of the MAF tube since it just barely fit on it.
Balasarius is offline   Reply With Quote
Old 06-30-2015, 06:26 AM   #5
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
I had the same problem. It seems like the hole in the air box is off a little. The filter slipped off MAF housing once when I drove it. When I got back, it took 2 of us to push it back on and tighten it down. I cranked the hell out of the clamp. It hasn't moved since.
Old 06-30-2015, 09:53 AM   #6
Balasarius
Balasarius's Avatar
Drives: 2015 ZL1
How did you know it slipped off? Did the engine throw a code or warning light?
Old 06-30-2015, 10:03 AM   #7
ZL1Naboz
ZL1Naboz
ZL1Naboz's Avatar
Drives: '13 ZL1, ‘53 Chevy Pickup, ‘22 GMC
what CAI are you using?
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno
559.92 RWHP 519 RWTQ
ZL1Naboz is offline   Reply With Quote
Old 06-30-2015, 01:07 PM   #8
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
I checked on it periodically after I installed it the first time. I noticed it barely fit like you were saying, so I just kept checking. Ever since I retightened it down, it's been good.
Old 06-30-2015, 01:13 PM   #9
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
It didn't throw a CEL though, but I would keep checking it. I tightened it down when it was hot, since the filter material gets really soft when it's hot.
Old 07-01-2015, 07:08 PM   #10
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
I thought the Cold Air Inductions CAI is the top dog in terms of fit, finish and performance. Should I be looking at something else??
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 07-01-2015, 07:45 PM   #11
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
It is. However, every car is "slightly" different, especially the way they choose to run all the wires under the hood.
Old 07-01-2015, 08:07 PM   #12
Shark72
Shark72's Avatar
What would the factory do different? I don't understand why the CAI should be a problem with some and not with others.
Old 07-02-2015, 09:40 AM   #13
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
The MAF wire is sometimes ran different which can cause the CAI MAF housing to not fit properly. Either way it's ran, the intake will fit. It's just harder to install dependin on how the wire is routed from the factory.
Old 07-02-2015, 10:05 AM   #14
Shark72
Shark72's Avatar
ZL WON
Thanks for the clarification!! What is your impression of the CAI now that you have some miles on it?
